Oui je le copie sur le Bloc note et le colle ensuite dans mon terminal en le modifiant comme il faut.
Yeah bu its not suposed to be 1 line of code its suposed to run it all at one time.
I can send you the photo in the worst case.
Run this to see if it pulls the image for you.
docker pull storjlabs/storagenode:beta
Yeah I get what its doing its not running the docker start command correctly.
root@srv1:/opt# docker pull storjlabs / storagenode: beta
“docker pull” requires exactly 1 argument.
See ‘docker pull --help’.
Usage: docker pull [OPTIONS] NAME[:TAG|@DIGEST]
Pull an image or a repository from a registry
root@srv1:/opt#
Are you copying and pasting it there shouldnt be any spaces anywhere.
I did not understand
Copiez-vous et collez-le, il ne devrait y avoir aucun espace nulle part.
on this order: docker pull storjlabs / storagenode: beta
Yes it should look like this
root@srv1:/opt# docker pull storjlabs/storagenode:beta
beta: Pulling from storjlabs/storagenode
Digest: sha256:be5424bd161cb4be135c45ba4e905ba301c22efba322e8263703fdbf84a73bb2
Status: Image is up to date for storjlabs/storagenode:beta
docker.io/storjlabs/storagenode:beta
root@srv1:/opt#
Ok, essayons maintenant de faire une autre commande de démarrage de docker et de recommencer à zéro, car les problèmes de copie et de collage à partir de ce site vissent des espaces importants qui ne devraient pas exister.
Maybe we can go through pastebin
Ok let me try to create it for you:
docker: Error response from daemon: invalid mount config for type “bind”: bind source path does not exist: /mnt/sda2/storage.
Ok least were getting somewhere make sure that location is created make a folder named storage
I confirm that / mnt / sda2 / storage is well created
make sure you can use cd /mnt/sda2/storage
