The logs are empty.
But at first glance it’s a problem with Iptables.
The logs are empty.
If it was running there would be at least something to log though.
Yes but there it does not launch. Can I copy and paste my iptable?
what happens when you try docker start storagenode
root@srv1:/mnt/sda2/storage# docker start storagenode
Error response from daemon: driver failed programming external connectivity on endpoint storagenode (8aa51b792eeecb0b607582195d4a1079e87422a61cef728653062172830f9d33): (iptables failed: iptables --wait -t filter -A DOCKER ! -i docker0 -o docker0 -p tcp -d 172.17.0.2 --dport 28967 -j ACCEPT: iptables: No chain/target/match by that name.
(exit status 1))
Error: failed to start containers: storagenode
Have you tried to reset the iptables
My iptable works properly with all the services I have and the open ports for STORJ.
voila mes regles Iptables
#STORJ : port 28967
$IPT -t filter -A INPUT -p tcp --dport 28967 -j ACCEPT
$IPT -t filter -A OUTPUT -p tcp --dport 28967 -j ACCEPT
$IPT -t filter -A INPUT -p tcp --dport 14002 -j ACCEPT
$IPT -t filter -A OUTPUT -p tcp --dport 14002 -j ACCEPT
J’ai reinstallé docker et tout est rentre dans l’ordre.
N’ouvrez pas le port 14002 à tout le monde! C’est seulement pour votre propre usage. Vous devez le restreindre à votre IP, ou transférer le port sur ssh.
