Storage Node Operators
Hi everyone,
I’m setting up 2 storage nodes in Lydney, UK but cannot access the registration site (https://registration.storj.io/) to get authorization tokens.
Current situation:
  • 2x 2TB nodes configured and running
  • Ports 28967 and 28968 forwarded correctly (tested open)
  • Nodes connecting to satellites but being heavily rate-limited
  • Dashboards show “offline” status due to rate limiting
  • Email: nicogreen1201@gmail.com
  • Wallet: 0x8B3EB765Fd4783E086E0C20b3F0F615CE077b011
Node IDs:
12eNVU5nHZZXLvPWd7VgFRGef6Fqm8nYrYxdVJKBdGTQGxeNLk1
1ePhd4Vm4i6tQYTTQDxCB3jCj49rwaMUMFyci5u7zzwnY2HuBt
Without authorization tokens, my nodes are stuck in extended vetting with heavy rate limiting.
Can anyone help me get tokens or suggest an alternative registration method?
Thanks!
Hello @N33KY,
The authorization token is not needed more than a year: Step 4. Create an Identity - Storj Docs
Nope. If dashboard shows offline - it’s not reachable form the satellite. Read the logs. Likely ddns isue, if the ports are actually open.
Stop the node while you investigate, otherwise satellites will start throttling attempts.
What is the basis of this claim?
Your nodes are still offline. Please use this article to troubleshoot:
