Hi to everyone, during the last few days I’ve tried to start a node (1st time for me).
I’ve done every step succesfully until was the moment to setting up the node.
I have modified the command to paste in the terminal window accordingly to the instructions
(for example “docker run --rm -e SETUP=“true” --mount type=bind,source=“C:\xxxxx\xxxxxx\AppData\Roaming\Storj\Identity\storagenode”,destination=/app/identity --mount type=bind,source=“D:\Storj”,destination=/app/config --name storagenode storjlabs/storagenode:latest”)
When I paste the command in Powershell it gives me this error:
" Error response from daemon: invalid mount config for type “bind”: invalid mount path: ‘/app/identity’.
See ‘C:\Program Files\Docker\Docker\Resources\bin\docker.exe run --help’."
What should I do for resolve this?
Thanks to everyone who can spend one moment for me.
Could you please post your docker run command (with identifying information removed)? Please post the command between three backticks ( ``` ) on the line above and below the block of text to keep the formatting. This will help check for errors.
I am unsure how to use docker from the command line in Windows. However, you could try changing the single backslashes to double back slashes in your paths.
My suggestion if this doesn’t work would be to use the docker GUI to set up your mounts first, or if you have no specific need to run docker, switch to the Windows GUI version of Storj.
Right click docker desktop icon in system tray. Go to Settings. Click Shared drives on the left. Check boxes next to C and D as you are storing identity in C and data in D.
