If you mean generated link by uplink share, then it will contain satellite, child API key, child encryption key and access rights.
Having this you can use it only for what the owner decided to share. The owner can revoke this access in any time.
If you would build a service like Mega on top of Tardigrade then probably the same would happen. As the Serviceprovider you would be asked to make sure that there is no copyrighted material uploaded. Only if you can manage to forward the encryption process to the user by offering an easy to use desktop tool or something you might be able to protect yourself (as Serviceprovider), but law enforcement can always force you to somehow bypass your security.
SNOs should be safe though as they have no way of knowing what they store and also no way of reconstructing the data.
There is no way to upload a file as is in the current implementation. You always uploads encrypted pieces. Neither Storj (Storage Node Operators) nor Storj Labs and Tardigrade can be sure what kind of data is uploaded. For all parties (except customer) those are random encrypted noise.
Perhaps you did not know, but each piece is transferring between uplink and storagenode directly without satellites via secure channel of course.
If you open a service to upload file your server would be client that encrypts the data, if you canāt forward it to the user, then you become responsible for the data
This is one of the reason that we do not have it. All such gateways always customersā deal.
If you want to upload and share - you must install the software on your end, which will encrypt and shred your data to pieces before uploading to the network.
I host sia/scprime too and they dont fill disk if you use zfs, this happens just in windows. At moment i host sia/scprime internxt and lot of storj nodes. And only storj cant be used with nfs, other coins support it and works ok. I dont like filecoin system requirements, its ridiculous just for hosting dataā¦
@Alexey any idea about making Storj.io and tardigrade.io more animate like https://filecoin.io/ so for the layman people who visits can just see that animation and may invest in Storj. Right now STORJ website has too much written content which is not easily explainable to the audience it requires techy person to understand those things.
I have the reverse opinion. I greatly dislike scrolling through the āPop and Wow!ā eye candy to get to the meat of how the technology actually works. Also, those fancy web pages use a lot of excess processing power⦠I typically search around for the 4 pt font āHow this actually worksā link⦠and then close the fancy landing page as fast as possible before my PCs fan kicks inā¦
wanted to try sia 3 years ago but didnāt get it working seemed a bit complicated at the timeā¦
i hear zfs for windows is still very temperamental, iām pretty happy with zfs for linux.
i bet one can make the whole nfs thing work⦠its a common database issue, did look into it a bit but ended up not bothering.
well storage is changing rapidly filecoin may simply be ahead of its time⦠saw some stuff on ⦠i forget what it was named, pretty new stuff atleast to me⦠was like storage and cpuās combined⦠so that stuff like search tasks didnāt take bandwidth from the main bus in a sense, it would be run locally on a drive⦠or thats the idea anyways⦠looked very interesting.
but yeah filecoin server demands does sound kinda absurd⦠havenāt really dug into it thoā¦
any notes on sia and scprime⦠and how they compare to storj from a āSNOā perspective?
good or bad experience?
Sia and scprime is long term projects too, last month lot of contracts expired and i think i collected about arround 40eur worth coins from sia. But all depends from used space and ofcourse downloaded/uploaded traffic. Just difference is you can change this price and not set too high as nobody will rent then. Scprime is new for renting and there is not lot of data now uploaded but they are working on enterprise s3 solution. At moment scprime is good that they pay Incentives to host node so if you have anyway free space then its worth to run it and get additional $$. Last month i got from Incentives running 3 nodes i get like 1200 coins (~50-60eur). But they told it will change based by price and uptime soon so who knows how profitable it will be. Anyway i think its better to run multiple services and not keep hdd spining for nothing as storj cant fill all space anyway
yeah thats exactly why iām browsing⦠i have extra capacity and looking at expanding my server even more to improve its profitability.
and like you say running multiple services just makes sense⦠all eggs in one basket and all thatā¦
when i returned to storj 6 months ago ingress was like 250-300gb a day so i was like⦠OMG must get more drives⦠so many more drives⦠and then it sort of died down again⦠but iām sure it will pickup again soonā¦
Forgot to mention about internxt, storj v2 clone. They pay 10eur for TB, but incoming traffic is so slow that it will take more than half year to fill node min payout
In your case its good to run multiple services as i readed you are running raid so then its simple to expand or migrate services to another pool if need more space so its smarter to use more services. Just now after 9 months i just started to receive some cash from storage hosting what is not cents so its very long investmentā¦
But now because of price rise what means we will receive less coins and shitty eth fee i think profit is a little bit fucked for storage nodes.
certain wonāt make one rich⦠and when including work spent and hardware wear⦠well⦠i donāt think small nodes will have much of an advantage thereā¦
mainly because i think when running 24/7 the data will most often degrade⦠if measures arenāt taken to ensure against it.
i tried golem, but thats sort of a hybrid⦠it can use storage space in the TB range, but itās for processing tasks⦠sounds really cool just didnāt get it to work⦠maybe ill try on a windows vm next⦠xD just seems so wasteful, but i suspect the project is made for that⦠or they are simply more than a few levels above me in linux abilitiesā¦
Storj is the best. Top 50 coin (token) easy, money will move from SIA to Storj. Storj is easier to set up so when more people set up their node they will back Storj.
SC and SCP are PoW coins which are mined by large farms and dumped on the market. This greatly affects the hosts trying to profit by providing disk space to the network as they get peanuts SC or SCP per TB and itās simply much easier to just straight out mine the coin in a few hours and you will get more $$$ than storing TBās of data for a full month. Makes no economical sense with the current storage pricing in SC or SCP, and SCP is trying to āfixā this by providing host incentives which is similar to what StorJ did to Surge pricing, however StorJ is not a PoW coin so it canāt be mined with ASICās and dumped on the market.
