Storj is moving node operator payouts and customer deposits to USDC
Starting with the October payout, Storj will pay all storage node operators in USDC instead of STORJ. At the same time, we’re switching the deposit option for paying your Storj service bill from STORJ to USDC.
Why we’re doing this
STORJ’s price has been highly volatile, especially through our Chapter 11 process. Payouts and deposits both involve an unavoidable delay: for node operators, the time it takes to receive STORJ and then move it onto an exchange and convert it to something less volatile; for customers, the time between buying STORJ on an exchange, withdrawing it, and having it arrive and post to their account. During that delay, the token’s value can shift significantly — usually not in your favor. USDC removes that risk. Its value stays pegged to the US dollar, so there’s no exchange-rate gap to lose money in between.
Many of you have asked for this directly on the forum. Regulated USD stablecoins are a fairly recent option. In the EU, USDC has been formally regulated since MiCA’s stablecoin rules took effect in June 2024. In the US, the GENIUS Act was signed in July 2025 and requires issuers to hold stablecoins on a 1-to-1 basis with US dollars or Treasuries. USDC works within both frameworks and runs on the same Ethereum infrastructure you already use.
The underliying token infrastructure stays in place, and the decision can be revisited if circumstances change.
What’s changing for node operators
  • Payouts are being switched from STORJ to USDC, starting with the October payout (sent from 2026-10-09T00:00:00Z onward).
  • You’ll need to make sure the wallet address on file can receive USDC. We’re waiting at least two weeks after this announcement before running the October payout specifically so you have time to update it if needed.
What’s changing for deposits
  • We’ll stop accepting STORJ as a deposit for Storj service fees and will accept USDC instead.
  • At the announcement, we’ll disable STORJ deposits in the satellite UI. USDC deposits will follow a few days later once that’s live — during that gap, deposits via the UI won’t be available.
  • The 10% deposit discount for STORJ deposits ends as of this announcement.
  • If you deposit USDC, we’ll still waive the $5/month minimum fee.
  • Any STORJ deposits and discounts already applied before this announcement stand as they are — nothing retroactive changes.
  • If you send STORJ after this announcement, it won’t be credited automatically. Open a support ticket and we’ll return it to you.
Timeline
  • 2026-09-17T00:00:00Z: September payout completed (last STORJ payout).
  • 2026-09-25T00:00:00Z: Announcement. STORJ deposits disabled in the satellite UI.
  • Late Sep: USDC deposits enabled in the satellite UI.
  • 2026-10-09T00:00:00Z onward: October payout runs in USDC.
If you have questions, reply here or reach out through support.
Update: USDC deposits are now live
Customers can now deposit USDC from the satellite UI. A few things to know:
  • USDC deposits are accepted on Ethereum (ERC-20) only. USDC sent on other networks won’t be credited.
  • Your deposit address hasn’t changed.
  • Using USDC still waives the $5/month minimum fee.
  • This month’s invoices run on Monday, October 5.
STORJ deposits are no longer credited. If you sent STORJ after the announcement, open a support ticket and we’ll return it.
For node operators, nothing changes from the original post: the first USDC payout is still planned for October 9. If your payout address is on an exchange, make sure it’s a USDC deposit address on Ethereum.
Thanks to everyone for the patience during the switch.
This is WONDERFUL, thank you for making this change. Great glory to Storj! :slight_smile:
While you’re at it, would it be possible to allow payments for storage in other cryptocurrencies as well, such as BTC, ETH etc? Using a payment processor like BitPay could ease the integration too. That might attract some smaller customers, individuals and such.
Hi
After this announcement I think need to put a lights on the following:
* What do we need to do to switch the wallet? Is it parameter Storj command options or something else?
* What will happen with Storj token?
This is great news! My wallet address is my storj account, because I always spend more on storj backup than what I earn from my little node. Should I change anything or will the transition be transparent?
The same way you configured your wallet address in the first place. If your wallet address does support USDC you don’t need to change anything. If your wallet address belongs to an exchange you might want to change that to the correct USDC deposit address otherwise the exchange might not process it.
What exactly you refer to with “October payout”?
I assume it is the payout of the services provided by node operators in September and paid in October. Please confirm.
So what do we do with Storj tokens?
@Grimm Sell them. You should not have any by now, they have been tanking in price ever since bankruptcy proceedings started. Although I have not checked recently.
@littleskunk Thanks for this change. Finally, storj has abandoned idea of their own currency for a simple exchange of services with node operators. You could now start sending payments like every other company - fiat, wire transfers, and so on. I hope these will come soon.
Regarding USDC payouts:
So our wallets are pointed to ETH address, right? And if that wallet can receive USDC on ETH, we don’t need to do anything? It’s going to be USDC on ETH, right?
The transition will be transparent. For now we have disabled token payment. We need to work on a few code changes before we reenable it. We expect to have everything working before the next storagenode payout. Customer deposit address will remain the same so the USDC payout should get processed to your account.
One note: No more 10% discount on the token payment. Thats the downside of this announcement.
With the chapter 11 running in the background its a bit harder to tell what the subject of the payout is. Lets just say the next payout will be in USDC independend of the context of that payout. It is technically a mix of prepayment and post adjustment of the previous prepayment.
Does this still apply:
“What happens to the token? Its utility in the network is unchanged today. We will not comment on price. Our stated goal is to propose a plan in which token holders can participate in ownership of the restructured company — subject to court approval, legal priorities, and definitive documentation.”
Yes that is correct. As long as you control the keys for that wallet you should be able to handle USDC just fine. The only people that need to change their wallets are people that send the payout directly to an exchange without controling the keys.
In this scenario, the STORJ token no longer seems to serve any real purpose. Has the token officially been completely abandoned? Can we consider it effectively dead from October onward, or are there any future plans for its use?
Ok, if so, it’s sounds fair
So as the Storj payments went to USDC, a no strong connections to ETH blockchain where STORJ token based, is it any possibility to make payments in a different blockchains?
I think it’s a win/win to everyone if it goes via (just for example, no adv) Tron (cause of low commissions)
Wow, huge news! This happened way sooner than expected!
Hopefully this doesn’t push node count up again :wink:
This is a good change, thank you!
I am going to say no. We might reactivate the token in the future. We just don’t see a reason right now to do so.
@littleskunk can we make node update, that it show values of smaller payout prices, as today it count with old prices, so will be lot of questions on payout day, as node show one thing, and payouts will be smaller.
