Hi there, my server shuts down due a power failure and now it show offline storj server, I already check the databases with - sqlite3 /path/to/storage/all_db_files.db “PRAGMA integrity_check;” - but all passed the check, the logs on storj are:
2022-11-11T11:36:30.307-0800 INFO piecestore uploaded {“Piece ID”: “C2GPJ3P6MIJ6MFYYF6N4ZXUNMV2WHBCLXY2HZV5FPIQDIDRVJIPQ”, “Satellite ID”: “12L9ZFwhzVpuEKMUNUqkaTLGzwY9G24tbiigLiXpmZWKwmcNDDs”, “Action”: “PUT”, “Size”: 151552}
2022-11-11T11:36:30.311-0800 INFO piecestore upload started {“Piece ID”: “55MOVVRSOBTNI34PSZCU2QTEL2NNMTKGRNUDCSKTYENH6EJ7RS7Q”, “Satellite ID”: “12EayRS2V1kEsWESU9QMRseFhdxYxKicsiFmxrsLZHeLUtdps3S”, “Action”: “PUT”, “Available Space”: 1995854753792}
2022-11-11T11:36:30.521-0800 ERROR piecestore failed to add bandwidth usage {“error”: “bandwidthdb: database disk image is malformed”, “errorVerbose”: “bandwidthdb: database disk image is malformed\n\tstorj.io/storj/storagenode/storagenodedb.(*bandwidthDB).getSummary:171\n\tstorj.io/storj/storagenode/storagenodedb.(*bandwidthDB).Summary:113\n\tstorj.io/storj/storagenode/storagenodedb.(*bandwidthDB).Add:52\n\tstorj.io/storj/storagenode/piecestore.(*Endpoint).beginSaveOrder.func1:731\n\tstorj.io/storj/storagenode/piecestore.(*Endpoint).Upload:445\n\tstorj.io/common/pb.DRPCPiecestoreDescription.Method.func1:220\n\tstorj.io/drpc/drpcmux.(*Mux).HandleRPC:33\n\tstorj.io/common/rpc/rpctracing.(*Handler).HandleRPC:61\n\tstorj.io/common/experiment.(*Handler).HandleRPC:42\n\tstorj.io/drpc/drpcserver.(*Server).handleRPC:122\n\tstorj.io/drpc/drpcserver.(*Server).ServeOne:66\n\tstorj.io/drpc/drpcserver.(*Server).Serve.func2:112\n\tstorj.io/drpc/drpcctx.(*Tracker).track:52”}
2022-11-11T11:36:30.521-0800 INFO piecestore uploaded {“Piece ID”: “55MOVVRSOBTNI34PSZCU2QTEL2NNMTKGRNUDCSKTYENH6EJ7RS7Q”, “Satellite ID”: “12EayRS2V1kEsWESU9QMRseFhdxYxKicsiFmxrsLZHeLUtdps3S”, “Action”: “PUT”, “Size”: 2816}
2022-11-11T11:36:30.624-0800 INFO Stop/Shutdown request received.
2022-11-11T11:36:30.635-0800 ERROR piecestore:cache error getting current used space: {“error”: “context canceled; context canceled; context canceled”, “errorVerbose”: “group:\n— context canceled\n— context canceled\n— context canceled”}
any idea how to fix this?
I’m running
Windows 11 Pro (21H2) build 22000.1219
Intel Xeon Processor
18 Ram
more than 50% space free on storage node and OS Disk
thanks in advance
