Storj node IP /24 - check and change
Is there a way to check if there is already a node in a given IP /24 class? E.g. does my neighbor with the same ISP have a node?
This is important for Storj policy reasons - one node per IP /24.
And what in the case of a variable IP, which can sometimes be at the same /24 and other times not?
Yes
http://storjnet.info/neighbors
Do you have complete instructions for installing this script on your server?
This is a third-party server. But you can contact an author.
