I am using docker to run my Storj node. My node’s status is currently showing ‘Offline’ in the dashboard. I checked the logs. Looks like new pieces are still being uploaded. What could be causing status to be shown offline on the dashboard?
My Storj node version is: v1.25.2
Welcome to the forum @rasodu !
Which browser are you using to check the dashboard ?
I am using Firefox. I checked the dashboard from other computer, also Firefox. It shows status as online. So, all good. Thanks!
You can try to hard refresh (Ctrl-F5) the dashboard where it’s not updated.
