Storj Share - Need help - How to setup again?
Hi Team,
I moved to a new place and have been running my old node for the past couple of months, however i think its not set-up properly. Can someone kindly help me on how to setup the node. I’ve approx 8 TB storage available.
Note:- I was referring to the old emails and most of the links shared earlier doesn’t work. For eg - https://docs.storj.io/v1.1/docs/storj-share-gui#section-311-ntp-synchronization-for-windows
Please help.
Thanks,
Below are my Node Ids for your reference,
6a200e43f4b35824cd54758d181cfc69841a7ebb
1aa26f1467e840dfdc8e594635b543bc8f97e3fb
94085b8a0af753ffd43c2932ada8ab30a462fdfc
Thanks,
Sure what do you need help with? Why do you think something is wrong with you node? If you need some more in depth help you can direct message me!
The v2 is deprecated and almost not used. You can subscribe to the waitlist to receive an invite to setup a new node on the beta v3 network: https://documentation.storj.io/
