Storj + SMART long test takes 15 days!
Not sure what you mean.
  1. I get a lot of: no such file or directory - it probably means that node deleted that sj1 file meanwhile - no problem
  2. Two times I got: I/O error - it means HDD can’t read the file as it contains an unreadable sector - these files I deleted. They can’t be recovered anyway.
  3. I never got: hash mismatch - it means that file is readable, but the content was altered - to produce this result I corrupted by hand a copy of one sj1 file just to see, how the output of is-valid-sj1-blob will look like. The real storj node files were of course not harmed during this experiment.
Long test on Exos 24TB SATA: 33 hours. :grin:
Oh, I thought you are got such messages. Otherwise everything should be fine.
Yes, that gives linear read speed of 200MB/s. Seems about right.
Just finished. It took 30 hours. That was the estimate with -c flag. 212MiB/s.
The time is also given by smartctl -a as e.g.
Short self-test routine
recommended polling time:        (   2) minutes.
Extended self-test routine
recommended polling time:        ( 523) minutes.
Conveyance self-test routine
recommended polling time:        (   5) minutes.
With piecestore, I tried ZFS with an SSD special device for metadata, and was impressed by how quickly e.g filewalkers got done. Would be my preferred way of setting up a piecestore.
However, now with hashstore, I don’t see much use for such tweaking, since there aren’t millions and millions of files to manage anymore.
Right, or we can abandon hashstore before it’s too late (extra code – extra bugs; this is effectively keeping pieces in a makeshift database; better version of this (using actual production tested database) was tried before and abandoned due to stability issues, in favor of a plain old filesytem tested by decades. Deletions taking long time is not a problem that requires solution.)
Furthermore, for most users SSD on the array either as a special device or cache dramatically improves experience, most arrays today have it; there is no reason not to add it, just for the sake of your users. And in this case storagenode gets to benefit from it for free.
You are right, the filewalker completes in minutes with tens of thousands of read IOPS, filesystem is perfectly fine managing many small files. Storj is not a large workload at all.
I keep watching these threads in disbelief and amusement – why are they purposefully destabilizing the codebase with extra unnecessary features?
To significantly increase the speed (it is in several times of the magnitude better than with a piecestore engine). I think we may post some tech blog there: Storj Engineering Blog | Storj Engineering Blog.
I often hearing from developers to promote it as a default storage engine, but there is no agreement on that.
