i have yet to find a good way without using network protocols to allow a vm access to a folder on my hypervisor host…seems like a pretty basic thing… and yet everything seems to be based upon different protocols…
virtualization is “still” kinda new, takes a long time for a technology to really mature… usually about a century, i think you might be able to do something like that with spice… and then select the vmware based graphics or something like that… ill have to check up on that…
i tried it out, didn’t think the workstation player was a hypervisor, figured it was a remote desktop thing, which i guess is what the vmware graphics thing is for…
ran into it when trying to do gpu passthrough, which was… “fun” as in a week of server crashes and tons of reboots… didn’t even get it to work…
but i did find out that spice drivers for the vm graphics and qemu drivers installed would make it run microsoft RDP so well that it was almost like using a local machine… can even do 1080p youtube… weird thing is that the server basically doesn’t have a graphic card/i took out the lowprofile nvidia card because the system was unstable… not a good one since it’s onboard and 10 years old…
ESXi isn’t cheap, runs up in the tens of thousands for big setups, but thats why it’s so good also… you get what you pay for…
but i’m very happy at being angry at my proxmox for free xD it does the job and it does it well + debian is very likely to become the future of the OS world, with all the development being put into that distribution… i just used zfs and is very new to linux… but i don’t regret making the change…
and i made lot of considerations before switching… really i wanted to go FreeBSD
but proxmox was what would install fast and on the first try… fought a bit with FreeBSD and other BSD’s maybe it was me or just some bios configuration…
anyways just wanted to say i understand what you are saying, and i’m not saying there is a perfect solution… just if somebody is use to EXSi then making the switch to proxmox might not seem worthwhile depending on the use case…
if i hadn’t been hating windows so much i might have gone windows storagespaces instead of zfs… and i’m not really sure i made the right choice in switching… because i’m basically lost in linux most of the time.
i like all my new options and the ability to always dig down and find a way to solve the issue, but i also miss the simplicity of windows and how it was default configured to just work well in most regards… if you need a firewall you turn it on and it basically minds itself… barely have to open ports or anything these days…
windows vs linux is a bit like you buy a new car…
the windows car is big and nice looking and everything just works, tho you cannot really change what you want…
the linux car is like an entire garage, with the car in the middle, and some tools come with it, its sleek, has good performance, but it is a bit of a gas hog… also it doesn’t have the butter smooth suspension of the windows car… but it’s still a very nice car… then you want to adjust your mirrors and you find out you have to take the door apart and install the cables for the mirrors because well everybody just assumes thats how that is done… and then you can ofc select which kinds of cables you want and how to control the mirror…
i mean it’s not like the car doesn’t work without the ability to move the mirrors, you just have to tilt your head a little… so it works… you just cannot simply adjust them
