storjWidget for iOS / Android
Did someone manage to install scriptable on android ?
I tried following the link to the apk but I can’t find how to download it.
Testing now, loving it! Maybe a small widget (the square version) could show four data points. Total bandwidth, monthly earnings, space used in percentage and nodes online?
Good work!
Good idea, I will create a small version once I find some time :slight_smile:
Hey, thanks for the cool idea.
Do I enter the IP address of my own StorJ node in the “NODE_List” and the url of my StorJ node in “myNodesIp.com:14002”?
Do I have to open port 3123?
still no update on an android version ?
Do you know any similar app but from google app store?
if node go offline docker logs :
ERROR in app: Exception on /bandwidth [GET]
File “/usr/local/lib/python3.7/site-packages/flask/app.py”, line 2447, in wsgi_app
response = self.full_dispatch_request()
File “/usr/local/lib/python3.7/site-packages/flask/app.py”, line 1952, in full_dispatch_request
rv = self.handle_user_exception(e)
File “/usr/local/lib/python3.7/site-packages/flask/app.py”, line 1821, in handle_user_exception
reraise(exc_type, exc_value, tb)
File “/usr/local/lib/python3.7/site-packages/flask/_compat.py”, line 39, in reraise
raise value
File “/usr/local/lib/python3.7/site-packages/flask/app.py”, line 1950, in full_dispatch_request
rv = self.dispatch_request()
File “/usr/local/lib/python3.7/site-packages/flask/app.py”, line 1936, in dispatch_request
return self.view_functionsrule.endpoint
File “/usr/src/app/app.py”, line 103, in get_data
getBandwidthData(satellitesResponse, data)
File “/usr/src/app/app.py”, line 46, in getBandwidthData
ingress = (satellitesResponse[‘bandwidthDaily’][relevantDay][‘ingress’][‘usage’] + satellitesResponse[‘bandwidthDaily’][relevantDay][‘ingress’][‘repair’])/1000000
TypeError: list indices must be integers or slices, not NoneType
IMG_6B26B8AD7F31-1
Just modified the layout in order to allow the small widget to be used properly.
I love it! Thank you.
Hey guys was anyone able to get it up and running on Windows?
tried to install the Flask server but no luck
Cool! :heart_eyes:
20 Characters…
Hmm which errors do you get? Missing dependencies?
Okay - totally new in this - how whould i go about installing it on windows? Its such a nice idea.
@striker43 Please - this is soo cool - but i cant get it to work on windows - can you help in any way? i tried with flask - but the program just returns “ERROR”
Unfortunately I don‘t have a windows pc right now so I can’t test it :neutral_face:
Are you using python version 3.7?
Can you post your error logs here?
I am using python 3.7 - i can try to post an error. when i open the “app” script with python it just closes and says “ERROR” - i tried to make an ENV with python 3.7 and flask and pip isntalled-
i tried to open CMD and type cd “LOCATION OF ENV” python app.py - that returns “ERROR” when i press enter.
if you have time and want to - i can maybe show you on discord or teamveiw or something - maybe we can post a step by step for others after (i can try to write it when i get it working)
THANK YOU in advance! @striker43
Tomorrow is a public holiday in my area, I can try to get it working on a windows pc then. I will let you know tomorrow.
Wow thank you alot! :smiley: @striker43
@Skyblockpro1 Did you get it working on windows?
@bivvo - did you do this on windows? if so - can you try to tell me how?
Did you try docker for windows?
That should work I think.
