Hello.
Today I spot some strange behavior:
It seems, that my node was cut off (from ~ 3:00 until ~ 15:00). Node as is was working (metrics for “StorjNode volume usage” and “StorjNode Trash usage”) I collect directly from node API endpoint.
As you can see, node slowly deleted some pieces (sent them to the trash), but no traffic come (metrics for “Volume disk space” I collecting from FS).
Traffic start coming again without any my actions.
From node logs I see many errors, but these errors still occurring. I mean, they are not specify to the strange time window:
2022-11-05T02:01:41.509238796Z 2022-11-05T02:01:41.508Z ERROR piecestore download failed {“Process”: “storagenode”, “Piece ID”: “NMHJTXAMWVJEJGHADJWZMUS2N2TDJGAFA3F3FPDLKRBD2NTQKQDA”, “Satellite ID”: “12L9ZFwhzVpuEKMUNUqkaTLGzwY9G24tbiigLiXpmZWKwmcNDDs”, “Action”: “GET”, “error”: “write tcp 172.17.0.3:28967->184.104.224.98:25922: use of closed network connection”, “errorVerbose”: “write tcp 172.17.0.3:28967->184.104.224.98:25922: use of closed network connection\n\tstorj.io/drpc/drpcstream.(*Stream).rawWriteLocked:326\n\tstorj.io/drpc/drpcstream.(*Stream).MsgSend:404\n\tstorj.io/common/pb.(*drpcPiecestore_DownloadStream).Send:317\n\tstorj.io/storj/storagenode/piecestore.(*Endpoint).Download.func5.1:628\n\tstorj.io/common/rpc/rpctimeout.Run.func1:22”}
2022-11-05T02:11:48.801523178Z 2022-11-05T02:11:48.801Z ERROR piecestore upload failed {“Process”: “storagenode”, “Piece ID”: “KQHHWTIJWJSN6J44ETST2NVPLV7CZ4OSMIPB7W4HMZOSJQMNIIPQ”, “Satellite ID”: “12L9ZFwhzVpuEKMUNUqkaTLGzwY9G24tbiigLiXpmZWKwmcNDDs”, “Action”: “PUT”, “error”: “unexpected EOF”, “errorVerbose”: “unexpected EOF\n\tstorj.io/common/rpc/rpcstatus.Error:82\n\tstorj.io/storj/storagenode/piecestore.(*Endpoint).Upload:349\n\tstorj.io/common/pb.DRPCPiecestoreDescription.Method.func1:220\n\tstorj.io/drpc/drpcmux.(*Mux).HandleRPC:33\n\tstorj.io/common/rpc/rpctracing.(*Handler).HandleRPC:61\n\tstorj.io/drpc/drpcserver.(*Server).handleRPC:122\n\tstorj.io/drpc/drpcserver.(*Server).ServeOne:66\n\tstorj.io/drpc/drpcserver.(*Server).Serve.func2:112\n\tstorj.io/drpc/drpcctx.(*Tracker).track:52”, “Size”: 311296}
Is this error alright? Was this interruption alright also?
Thank you for feedback!
