Troubleshoot yellow warning for suspension score
Hello, same problem here. All of a sudden two satellites suspended my node… I have been checking last time maybe two hours ago and everything was fine.
I ran the successrate script and here is the result (which doesn’t look that bad…):
/home/storj/STORJ/bin/successrate.sh storagenode.log
LOG: storagenode.log
Critically failed:     0
Critical Fail Rate:    0.000%
Recoverable failed:    0
Recoverable Fail Rate: 0.000%
Successful:            56
Success Rate:          100.000%
dl_canratio: 10.978%
Failed:                510
Fail Rate:             2.873%
Canceled:              1949
Cancel Rate:           10.978%
Successful:            15295
Success Rate:          86.150%
Rejected:              0
Acceptance Rate:       100.000%
Failed:                6
Fail Rate:             0.011%
Canceled:              56
Cancel Rate:           0.104%
Successful:            53931
Success Rate:          99.885%
Failed:                41
Fail Rate:             1.310%
Canceled:              0
Cancel Rate:           0.000%
Successful:            3089
Success Rate:          98.690%
Failed:                0
Fail Rate:             0.000%
Canceled:              2
Cancel Rate:           0.036%
Successful:            5538
Success Rate:          99.964%
Failed:                0
Fail Rate:             0.000%
Successful:            14812
This is confirmed by looking into storagenode.log:
 grep -E "GET_AUDIT" storagenode.log|grep 12L9ZFwhzVpuEKMUNUqkaTLGzwY9G24tbiigLiXpmZWKwmcNDDs
2022-06-13T01:50:08.605+0200	INFO	piecestore	download started	{"Process": "storagenode", "Piece ID": "L4IWHSLBSMK6NWCP7MD6EFDAJ5UTA42M433FX7GQYKSFK2V4JV7Q", "Satellite ID": "12L9ZFwhzVpuEKMUNUqkaTLGzwY9G24tbiigLiXpmZWKwmcNDDs", "Action": "GET_AUDIT"}
2022-06-13T01:50:08.707+0200	INFO	piecestore	downloaded	{"Process": "storagenode", "Piece ID": "L4IWHSLBSMK6NWCP7MD6EFDAJ5UTA42M433FX7GQYKSFK2V4JV7Q", "Satellite ID": "12L9ZFwhzVpuEKMUNUqkaTLGzwY9G24tbiigLiXpmZWKwmcNDDs", "Action": "GET_AUDIT"}
2022-06-13T02:00:15.063+0200	INFO	piecestore	download started	{"Process": "storagenode", "Piece ID": "KLJZXUNBXO7L5JFGSH2A2W2ESJLGRVPQ6PQSOXZORNNYOSHAMBQA", "Satellite ID": "12L9ZFwhzVpuEKMUNUqkaTLGzwY9G24tbiigLiXpmZWKwmcNDDs", "Action": "GET_AUDIT"}
2022-06-13T02:00:15.179+0200	INFO	piecestore	downloaded	{"Process": "storagenode", "Piece ID": "KLJZXUNBXO7L5JFGSH2A2W2ESJLGRVPQ6PQSOXZORNNYOSHAMBQA", "Satellite ID": "12L9ZFwhzVpuEKMUNUqkaTLGzwY9G24tbiigLiXpmZWKwmcNDDs", "Action": "GET_AUDIT"}
2022-06-13T07:37:09.589+0200	INFO	piecestore	download started	{"Process": "storagenode", "Piece ID": "NZJW2CEB7HHBDWBORD5OLGXQNN4LEDSXJD5HGYZVPZEGAED7JKNA", "Satellite ID": "12L9ZFwhzVpuEKMUNUqkaTLGzwY9G24tbiigLiXpmZWKwmcNDDs", "Action": "GET_AUDIT"}
2022-06-13T07:37:09.662+0200	INFO	piecestore	downloaded	{"Process": "storagenode", "Piece ID": "NZJW2CEB7HHBDWBORD5OLGXQNN4LEDSXJD5HGYZVPZEGAED7JKNA", "Satellite ID": "12L9ZFwhzVpuEKMUNUqkaTLGzwY9G24tbiigLiXpmZWKwmcNDDs", "Action": "GET_AUDIT"}
2022-06-13T09:50:41.330+0200	INFO	piecestore	download started	{"Process": "storagenode", "Piece ID": "ACJ4K7KOTV7BDBOHJN3GFRZHHUWRI3F5CE3B2AW5QIXC24IFQ4VQ", "Satellite ID": "12L9ZFwhzVpuEKMUNUqkaTLGzwY9G24tbiigLiXpmZWKwmcNDDs", "Action": "GET_AUDIT"}
2022-06-13T09:50:41.587+0200	INFO	piecestore	downloaded	{"Process": "storagenode", "Piece ID": "ACJ4K7KOTV7BDBOHJN3GFRZHHUWRI3F5CE3B2AW5QIXC24IFQ4VQ", "Satellite ID": "12L9ZFwhzVpuEKMUNUqkaTLGzwY9G24tbiigLiXpmZWKwmcNDDs", "Action": "GET_AUDIT"}
2022-06-13T11:22:16.236+0200	INFO	piecestore	download started	{"Process": "storagenode", "Piece ID": "RHAOJUL4U3EYFQZ5DXOSBQROYRQUZUD6PYXTXR23BDWJUSTIOIPQ", "Satellite ID": "12L9ZFwhzVpuEKMUNUqkaTLGzwY9G24tbiigLiXpmZWKwmcNDDs", "Action": "GET_AUDIT"}
2022-06-13T11:22:16.482+0200	INFO	piecestore	downloaded	{"Process": "storagenode", "Piece ID": "RHAOJUL4U3EYFQZ5DXOSBQROYRQUZUD6PYXTXR23BDWJUSTIOIPQ", "Satellite ID": "12L9ZFwhzVpuEKMUNUqkaTLGzwY9G24tbiigLiXpmZWKwmcNDDs", "Action": "GET_AUDIT"}
2022-06-13T11:40:47.459+0200	INFO	piecestore	download started	{"Process": "storagenode", "Piece ID": "Q3CFTAORTA5FYUIBMRY2Z3T35CAS45FWDEAZR5TE6JEDNMFX2YWQ", "Satellite ID": "12L9ZFwhzVpuEKMUNUqkaTLGzwY9G24tbiigLiXpmZWKwmcNDDs", "Action": "GET_AUDIT"}
2022-06-13T11:40:48.291+0200	INFO	piecestore	downloaded	{"Process": "storagenode", "Piece ID": "Q3CFTAORTA5FYUIBMRY2Z3T35CAS45FWDEAZR5TE6JEDNMFX2YWQ", "Satellite ID": "12L9ZFwhzVpuEKMUNUqkaTLGzwY9G24tbiigLiXpmZWKwmcNDDs", "Action": "GET_AUDIT"}
2022-06-13T14:16:40.094+0200	INFO	piecestore	download started	{"Process": "storagenode", "Piece ID": "IXF3VO6VXKO6MSDGJ4EUFD6V54V64MNPKTRREEP2IGZ26X6W5EYA", "Satellite ID": "12L9ZFwhzVpuEKMUNUqkaTLGzwY9G24tbiigLiXpmZWKwmcNDDs", "Action": "GET_AUDIT"}
2022-06-13T14:16:40.252+0200	INFO	piecestore	downloaded	{"Process": "storagenode", "Piece ID": "IXF3VO6VXKO6MSDGJ4EUFD6V54V64MNPKTRREEP2IGZ26X6W5EYA", "Satellite ID": "12L9ZFwhzVpuEKMUNUqkaTLGzwY9G24tbiigLiXpmZWKwmcNDDs", "Action": "GET_AUDIT"}
2022-06-13T14:46:41.411+0200	INFO	piecestore	download started	{"Process": "storagenode", "Piece ID": "YCNLXBN5HHST5DYZMRADMFAMAYNWTDGOAS3RNRGIFPGVUPATWWQQ", "Satellite ID": "12L9ZFwhzVpuEKMUNUqkaTLGzwY9G24tbiigLiXpmZWKwmcNDDs", "Action": "GET_AUDIT"}
2022-06-13T14:46:41.652+0200	INFO	piecestore	downloaded	{"Process": "storagenode", "Piece ID": "YCNLXBN5HHST5DYZMRADMFAMAYNWTDGOAS3RNRGIFPGVUPATWWQQ", "Satellite ID": "12L9ZFwhzVpuEKMUNUqkaTLGzwY9G24tbiigLiXpmZWKwmcNDDs", "Action": "GET_AUDIT"}
2022-06-13T17:25:13.190+0200	INFO	piecestore	download started	{"Process": "storagenode", "Piece ID": "SDVCAGWZQEL6PBPXIWFLA5WDTINVS4EECE7ITZMN4IIGCULRV46A", "Satellite ID": "12L9ZFwhzVpuEKMUNUqkaTLGzwY9G24tbiigLiXpmZWKwmcNDDs", "Action": "GET_AUDIT"}
2022-06-13T17:25:13.323+0200	INFO	piecestore	downloaded	{"Process": "storagenode", "Piece ID": "SDVCAGWZQEL6PBPXIWFLA5WDTINVS4EECE7ITZMN4IIGCULRV46A", "Satellite ID": "12L9ZFwhzVpuEKMUNUqkaTLGzwY9G24tbiigLiXpmZWKwmcNDDs", "Action": "GET_AUDIT"}
You need to check not only GET_AUDIT, but also GET_REPAIR, since it affects audit and suspension scores too. Please search only for errors.
Regarding missing errors - if you re-created the container and did not redirect logs, the previous logs got deleted with the container. So in such case you can see only logs since the last container creation.
