Hi guys,
This is the second step in How to run your own satellite - first step is here.
Currently at this time, the only distributed database supported are google spanner and cockroachdb (there are likely TiDB will be there in the future). At this point, I can only recommed cockroachdb.
Manually set up cockroachdb cluster is a great pain, though I still recommend you do it once to understand how it work, but not a second time. I’ve write a script for you, it automate the entire process:
- Generate cluster certificate
- Generate node certificate and set up timeserver (choose google time server as it deal with Time smearing)
- Generate client certificate
- Init cluster
Notice that: cockroachdb cluster can be 1 node (a real cluster, not single-node-cluster), you can create a 1 node cluster first and add more nodes later, does not need to be at least 3 nodes like in official doc recommendation.
To use this script: you need a binary cockroach (you can download it from their site), unzip and copy this script to it directory and run with root, it will handle set up from there.
#!/bin/bash
if [ "$(id -u)" -ne 0 ]; then
echo -e "\033[1;31mERROR: must be running as root, exit code 1\033[0m" >&2
exit 1
fi
SCRIPT_DIR="$(cd "$(dirname "${BASH_SOURCE[0]}")" && pwd)"
OS_ID=$(grep ^ID= /etc/os-release | cut -d= -f2 | tr -d '"')
if [[ ! -f "$SCRIPT_DIR/cockroach" && ! $(command -v cockroach) ]]; then
echo -e "\033[1;31mERROR: cockroach not exist in $SCRIPT_DIR dir and \$PATH, exit code 2\033[0m" >&2
exit 2
fi
if [[ -f "$SCRIPT_DIR/cockroach" ]]; then
COCKROACH=$SCRIPT_DIR/cockroach
else
COCKROACH=$(command -v cockroach)
fi
# 0. ASK IF CREATE NEW CLUSTER OR
# ADD NODE TO EXISTING CLUSTER
while true; do
echo "1) create new cluster cert"
echo "2) create node cert, setup and start node"
echo "3) create client cert"
echo "4) init cluster"
echo "5) cockroach sql shell"
read -rp "Choose an option [1-5]: " choice
case "$choice" in
1)
echo "You selected: create new cluster cert"
CHOICE=1
break
2)
echo "You selected: create node cert, setup and start node"
CHOICE=2
break
3)
echo "You selected: create client cert"
CHOICE=3
break
4)
echo "You selected: init cluster"
CHOICE=4
break
5)
echo "You selected: cockroach sql shell"
CHOICE=5
break
echo "Invalid option. Please select 1,2,3,4 or 5."
esac
done
if [[ $CHOICE = 5 ]]; then
$COCKROACH sql --certs-dir=$SCRIPT_DIR --host=127.0.0.1
fi
if [[ $CHOICE = 4 ]]; then
$COCKROACH init --certs-dir=$SCRIPT_DIR --host=127.0.0.1
fi
if [[ $CHOICE = 3 ]]; then
if [[ -f "$SCRIPT_DIR/client.root.crt" || -f "$SCRIPT_DIR/client.root.key" ]]; then
echo "But client.root.crt or client.root.key exist in $SCRIPT_DIR, exit code 10"
echo "(fix: delete client.root.crt and client.root.key in $SCRIPT_DIR)"
exit 10
fi
$COCKROACH cert create-client root --certs-dir="$SCRIPT_DIR" --ca-key="$SCRIPT_DIR/ca.key"
fi
if [[ $CHOICE = 2 ]]; then
if [[ ! -f "$SCRIPT_DIR/ca.crt" ]]; then
echo "But ca.crt not exist in $SCRIPT_DIR, exit code 4"
echo "(fix: copy ca.crt and ca.key to $SCRIPT_DIR)"
exit 4
fi
if [[ -f "/etc/systemd/system/cockroachdb.service" ]]; then
echo "/etc/systemd/system/cockraochdb.service already exist, exit code 9"
echo "(fix: remove cockroachdb.service)"
exit 9
fi
fi
echo -e ""
echo "This current machine will be the one run the node?"
select choice2 in "yes" "no"
do
case "$choice2" in
"no")
echo "This machine must be the one will run node, exit code 5"
exit 5
"yes")
echo "Start installing.."
break
echo "Invalid option. Please select 1 or 2."
esac
done
fi
if [[ $CHOICE = 1 ]]; then
if [[ -f "$SCRIPT_DIR/ca.crt" ]]; then
echo "But ca.crt already exist, exit code 3"
echo "(fix: delete ca.crt and ca.key in $SCRIPT_DIR to reset)"
exit 3
fi
fi
# 1. SET UP NTP
if [ $OS_ID = 'debian' ] || [ $OS_ID = 'ubuntu' ]; then
export DEBIAN_FRONTEND=noninteractive
apt install -y -qq ntpsec
sed -i '/^pool /d' /etc/ntpsec/ntp.conf
for s in time1.google.com time2.google.com time3.google.com time4.google.com; do
line="server $s iburst"
grep -qxF "$line" /etc/ntpsec/ntp.conf || echo "$line" >> /etc/ntpsec/ntp.conf
done
service ntpsec restart
fi
fi
# 2. GENERATE CLUSTER CERTIFICATE
echo "-- CREATE ca.crt AND ca.key --"
chmod +x "$SCRIPT_DIR/cockroach"
$COCKROACH cert create-ca --certs-dir="$SCRIPT_DIR" --ca-key="$SCRIPT_DIR/ca.key"
echo "NOTE: backup ca.key in a safe place"
fi
# 3. GENERATE NODE CERTIFICATE
echo "-- CREATE node.crt AND node.key --"
if [[ -f "$SCRIPT_DIR/node.crt" || -f "$SCRIPT_DIR/node.key" ]]; then
echo "node.crt exists, exit 6"
echo "(fix: delete node.crt)"
exit 6
fi
if [[ -f "$SCRIPT_DIR/node.key" ]]; then
echo "node.key exists, exit 7"
echo "(fix: delete node.key)"
exit 7
fi
echo
echo "Please add domain node will serve from eg: example.com, using comma as separator,"
echo "for example: 192.168.10.9,load_balancer1,lb2,1.2.3.4,2.3.4.5,10.9.8.7,example.com"
echo "note: script already detect private IP and loopback and hostname, avoid add dynamic public IP"
read -r -p "Domain:" lb_input
lb_output="${lb_input//,/ }"
ip_v4=""
ip_v6=""
# if ip_v4 exist
if ip -4 route get 1.1.1.1 > /dev/null 2>&1; then
ip_v4=$(ip route get 1.1.1.1 | awk '{for(i=1;i<=NF;i++) if($i=="src") print $(i+1)}')
fi
# if ip_v6 exist
if ip -6 route get 2606:4700:4700::1111 > /dev/null 2>&1; then
ip_v6=$(ip -6 route get 2606:4700:4700::1111 | awk '{for(i=1;i<=NF;i++) if($i=="src") print $(i+1)}')
fi
lb_output="$lb_output $ip_v4 $ip_v6 127.0.0.1 $HOST localhost"
$COCKROACH cert create-node --certs-dir="$SCRIPT_DIR" --ca-key="$SCRIPT_DIR/ca.key" $lb_output
fi
# 4. GENERATE SERVICE FILE
advertise_port=26257
default_addr="${lb_input}:${advertise_port}"
echo
echo "Advertise address?"
read -e -i "$default_addr" -p "--advertise-addr=" advertise_addr
echo $advertise_addr
crdb_rdv="crdb.rdv.example.com:26257"
echo
echo "Join node? (should use a domain for DDNS, eg: $crdb_rdv)"
read -r -p "--join=" crdb_rdv
echo
echo "Locality (eg: continent=NA,country=US,region=US-EAST-1,provider=AWS,zone=A)"
read -e -i "continent=NA,country=US,region=US-EAST-1,provider=AWS,zone=A" -p "--cache=" locality
echo $locality > $SCRIPT_DIR/locality_file
echo
echo "Max cache (0.1-1)?"
read -e -i "0.25" -p "--cache=" cache_perc
echo
echo "Max sql memory (0.1-1)?"
read -e -i "0.25" -p "--cache=" max_sql_memory
echo "cockroachdb.service already exist, exit code 8"
exit 8
fi
touch /etc/systemd/system/cockroachdb.service
cat << EOF > /etc/systemd/system/cockroachdb.service
[Unit]
Description=Cockroach Database Node
Requires=network.target
[Service]
Type=notify
WorkingDirectory=$SCRIPT_DIR
ExecStart=$SCRIPT_DIR/cockroach start --certs-dir=$SCRIPT_DIR --advertise-addr=$advertise_addr --join=$crdb_rdv --cache=$cache_perc --max-sql-memory=$max_sql_memory --locality-file=$SCRIPT_DIR/locality_file
TimeoutStopSec=300
Restart=always
RestartSec=10
User=root
[Install]
WantedBy=default.target
EOF
systemctl enable cockroachdb
systemctl start cockroachdb
fi
fi
Thanks for reading, hope to see you in part 3.
If you have any question, let me know, I’m happy to answer it.
P/s: cockroachdb required you to register an account to get a license key (free - but need to do it yearly), or you can use a fork.
Update Aug 10
Look like CRDB support will go away, we could match postgres implementation via a few methods:
# match transaction isolation level
# affect entire cluster except for root user
alter role all set default_transaction_isolation = 'read committed';
This will ensure fewer CRDB 40001 error, for important transaction, storj already handle by increase isolation level.
