I found an article about TCP FAST OPEN on geeksforgeeks.org and there it says:
" The total amount of data piggybacked with the SYN packet must be within specified limits.
What is the specified limit? A total of 1460 bytes can be piggybacked into the packet for IPv4. Therefore, the size of one segment becomes 1460 B."
Is this reffering to MTU size? We should set a recomanded value? Now I have 1500 and 1492 on 2 ISPs. Are these OK?
Sorry for spamming, but I try to make the best decitions here for my nodesâŚ
I have an 1GB RAM Synology, with 2 nodes on it.
Should I enable TCP Fast Open? Dose it depends on RAM?
Thanks!
I put it here also just to make Storj team aware of thisâŚ
I use Synology NAS + Docker, Storagenode v 1.75.2, DSM (7.1.1-42962 Update 4) and Docker (20.10.3-1308) up-to-date. All commands and storagenode run in sudo su mode.
I set:
and I get this error and storagenode dosenât run:
docker: Error response from daemon: OCI runtime create failed: container_linux.go:367: starting container process caused: process_linux.go:495: container init caused: write sysctl key net.ipv4.tcp_fastopen: open /proc/sys/net/ipv4/tcp_fastopen: no such file or directory: unknown.
I remove storagenode and than run it without the --sysctl net.ipv4.tcp_fastopen=3. It runs fine.
I try these commands and I get this:
cat /proc/sys/net/ipv4/tcp_fastopen
3
docker exec -it storagenode cat /proc/sys/net/ipv4/tcp_fastopen
3
cat: /proc/sys/net/ipv4/tcp_fastopen: No such file or directory
Whatâs with this error and why docker shows 3?
EDIT:
After NAS restart, the docker exec dosenât show 3, only the error.
The log shows this:
INFO server kernel support for tcp fast open unknown {"Process": "storagenode"}
