Unable to connect to node dashboard
When you deleted your databases, did you happen to accidentally delete the storage-dir-verification file?
nope. Still there. Deleted only the .db files.
are you able to verify that your current storagenode.exe able to run on your system and show the version?
What do you mean if it is able to run on the system? I’ve been running the node for a long time. Here is the result.
PS C:\Program Files> cd .\Storj
PS C:\Program Files\Storj> cd '.\Storage Node'
PS C:\Program Files\Storj\Storage Node> .\storagenode.exe version
2024-07-12T20:27:45-04:00 INFO Anonymized tracing enabled {ā€œProcessā€: ā€œstoragenodeā€}
Release build
Version: v1.105.4
Build timestamp: 29 May 24 08:48 EDT
Git commit: e20f78fa5d0e07eecfb615aa8b74075c7ae25b92
EDIT: Weird - your pic shows configuration file loaded yet mine does not - only anonymized tracing enabled. Perhaps it is as I have the services disabled currnetly (otherwise it just keeps starting , erroring / restarting / etc…) This error when I start the service.
Also stumped as to why it won’t recreate the log file.
It looks like you have the same EXE file as me, so I’m guessing it’s ok. I was just wondering if you accidentally downloaded some weird version while trying to manually go back to a specific version. I’m still tinkering on my end.
I didn’t think I did - was pretty straight forward to get the version once I was directed.
Can you check your windows event viewer for errors?
As above. That’s why I disabled the service.
The Storj V3 Storage Node service terminated unexpectedly. It has done this 1 time(s). The following corrective action will be taken in 0 milliseconds: Restart the service.
I can’t even try some of the suggestions from other posts (eg - ```
cat ā€œ$env:ProgramFiles/Storj/Storage Node/storagenode.logā€ -tail 40
what if you try running the exe from the command line (command line run as administrator)
cd C:\Program Files\Storj\Storage Node
storagenode.exe run --log.output stderr --config-dir "C:\Program Files\Storj\Storage Node\\"
Error: While parsing config: yaml: line 170: mapping values are not allowed in this context
EDIT: Seems like a directory error (storage path was missing a trailing \
It’s running now - what is it doing?
Interesting. What is it doing? I don’t know. You might want to press control +c until it stops and try to run it the normal way instead of using the command line now that you have fixed a config.yaml issue.
Sorry - had to create another account as my new account was restricted from further posting. Wasn’t sure what it was doing - just processing / activity it looked like.
Rebooted - storj service ok - updater service stopped (no worry with that)
Looks like it’s catching up - jumped from 500mb to 1.20gb… will watch.
Rebooting now to see what happens…
Nice. Just curious. Did it re-generate your log file and databases?
EDIT:
lol. I think if someone hasn’t yet, they will soon enough. :slight_smile:
Also, it’s very annoying to be limited to posts as a new account when troubleshooting. Maybe consider that (mods) when someone newly registers trying to troubleshoot - lots of messages going back and forth - typically in a panic.
It did. with db and db-wal files (don’t know what the wal files are)
2024-07-12T21:31:18-04:00 INFO piecestore uploaded {ā€œPiece IDā€:
Log entries just thos now… seems ok.
Thanks for your TS!
Seems I lost a bit of credibility.
No problem, Glad you got it working. I know the feeling of a node that won’t start. I’ve broken mine more than I care to admit.
