when i start , i got the following error
Unable to find image ‘storjlabs/storagenode:arm’ locally
arm: Pulling from storjlabs/storagenode
1df32bae7504: Pull complete
1af565b30770: Pull complete
cad107e1fe5e: Pull complete
c3b7dfadbd9b: Pull complete
0f5872de38cc: Pull complete
30e17bee2bdb: Pull complete
0d0042d1f958: Pull complete
3470ec014eac: Pull complete
Digest: sha256:7b2cdd7174efe913379b0fcb54c810f0beea3f1ff8de5b7de381b88c0eb22c56
Status: Downloaded newer image for storjlabs/storagenode:arm
docker: Error response from daemon: ttrpc: client shutting down: read unix @->@/containerd-shim/moby/5f12c497cfaadff89fed1778b0df18fb91d49f60cba382297f8264bc6bd77423/shim.sock: read: connection reset by peer: unknown.
ERRO[0028] error waiting for container: context canceled
anyone can help?
You should be using storjlabs/storagenode:beta for arm nodes as well.
thanks, but i got the same error
Unable to find image 'storjlabs/storagenode:beta' locally
beta: Pulling from storjlabs/storagenode
Status: Downloaded newer image for storjlabs/storagenode:beta
docker: Error response from daemon: ttrpc: client shutting down: read unix @->@/containerd-shim/moby/1a7324420b4aea8eb02b335f5a223b432a4c903b53dc799318f77a6d5c34e537/shim.sock: read: connection reset by peer: unknown.
ERRO[0027] error waiting for container: context canceled
Alexey
4
Please, copy the text output of the top command here.
and docker --version
thanks for the help, i just format the sd card and start all over again. it works now.
