Billing show 1tb usage limit. Billing also want to charge for 1.25Tb
So you are expecting the system to hard stop you from uploading any more files, and since this is currently not implemented, you expect not to be charged for the actual usage over limit you incurred? Note that you did not get charged in the first billing period for any usage.
it will be very polite to send to client email, that he reach limit or reach it after some space.
Exactly! I saw the limits and thought, āsince they are specified, I canāt use more traffic than within the limit and will not pay for overusageā
Why?
I have forwarded your request to our marketing team, so hopefully they will implement emails to be triggered in the event an account reaches usage limits.
Even better would be something configurable so the user can decide what happens if the limit is reached: completely deny uplink requests or send email and continue to work.
You did not get charged for usage in the first billing period because of the $55 coupon (otherwise known as 1 TB coupon). Your total usage was less than what was covered by the coupon during that billing cycle. I already explained this in detail here
The dev team is currently doing tests to determine if limits are not working as expected, so they can apply a fix if needed. I donāt believe (I may be wrong) that it is intentional that usage could go over the limits. So for now, while the dev team works on this issue, I think we can only ask for the email alerts. If it turns out that exceeding the limits should be optional, then I agree your configurable option would be a good future improvement.
Look at my pictures, limits are broken
1.25Tb of 1Tb possible
This is why were here testing thats the entire point is finding issues and letting them know the issues. You found an issue they will fix the issue to stop it from happening.
Just read storj position about bugs
My problem:
Itās a different problem, not the bug with traffic limit, please, do not mix all to one.
Moved back to the right thread
Nope. Same problem: billing is awful. You want to charge money for YOUR bugs.
Itās not true. We charge you for your usage.
Yes the limit have not worked. This bug is now should be fixed. However, the usage is real despite the broken limit.
By the way - thank you for pointed to that bug, itās helped to fix it earlier.
Still feels like there should be a little discount or something from StorjLabs when a customer experiences a bug⦠? A way to say āsorry for the inconvenienceā?
My Internet Provider does that for instance: one month I got a 50% discount because their service was degraded for some reasonsā¦
Problem solved.
