I have a StorJ node up and running since May 2019 if I’m correct.
Everything was working smooth till last month when I had internet problems.
It was 3 or 4 days offline. After that was ver. 26.2 and the amount of data drasticly dropped.
During all December I received 2GB but it appeared to work - was online.
Now with the 27.1 I also changed the running command as I read should be done.
Actually I can not make it up and running again.
Using Windows 10 and docker on it.
My old command was:
docker run -d --restart unless-stopped -p 28967:28967 -e WALLET=“0x07e0880E89e0dBAf096dBb703C0ED70000000000” -e EMAIL=“gmail” -e ADDRESS=“000.hopto.org:28967” -e BANDWIDTH=“100TB” -e STORAGE=“960GB” -v “S:\!!!\Storj\Identity\storagenode\”:/app/identity -v “S:\storj\”:/app/config --name storagenode storjlabs/storagenode:alpha
My new command is:
docker run -d --restart unless-stopped -p 28967:28967 -p 127.0.0.1:14002:14002 -e WALLET=“0x07e0880E89e0dBAf096dBb703C0ED74000000000” -e EMAIL=“gmail” -e ADDRESS=“000.hopto.org:28967” -e BANDWIDTH=“100TB” -e STORAGE=“1TB” --mount type=bind,source=“S:\!!!\Storj\Identity\storagenode\”,destination=/app/identity --mount type=bind,source=“S:\storj\”,destination=/app/config --name storagenode storjlabs/storagenode:beta
When I start the node and try to start dashboard I receive the messege that container is restarting and i should wait till its up
You need to fix your database file since its corrupted.
Remove the last \. Use \\ instead of single \so it becomes S:\\!!!\\Storj\\Identity\\storagenode
Do this for all your paths so they have \\
You have changed from 960GB to 1TB make sure you have 10% overhead. Don’t over allocate and get your node in trouble. Your physical free space should be 1TB+10% overhead so 1100GB since 1TB drive usually have ~930GB usable.
Open the Docker desktop settings, clear disks selection and click the “Apply”, then select your disks back and click the “Apply” again.
Remove the config.yaml from the S:\storj\
Then run your container again with all your parameters.
Then check logs:
