I believe the satellite tracks the time from the moment your node sais it stored the piece until the client send delete command, or the TTL is reached. I don’t know what’s the minimum time frame (unit) for messurement. Maybe it’s 1 hour, or 1 min, or less, but you get paid for the above mentioned time period.
I see. You are correct, I missed the point, I’m sorry.
…not enough sleep than not enough coffee…
and @nerdatwork is right, I didn’t see what you were referring to and that confused me.
Do you know the granularity of the calculations?
Hours? Minutes? Seconds? Something else entirely?
Nanosecods! (or maybe even more precise)
Ugh.
Search is your friend. Sorry I was lazy and thank you ![]()
I only found it fast, because it was my question being answered, otherwise it would have been difficult
Please tell me, is the function of saving the current scanning position when the filewalker is running already working? Or is work still underway?
We are going to test 3 alternative node selections today. It would be great to get some feedback how each of them impacts your nodes.
- choice of 2 (test run finished a few minutes ago)
- bestofn with an factor of 2 (API pods currenty restarting. Test should start in about 10 minutes)
- choiceofn with n=3
- filterbest (not sure about the exact config for this one yet)
Awesome to see more options being tested.
Could you elaborate a little? 1 and 2 sound effectively the same. And what does filterbest mean?
My plan was to describe them later. For now we just need to find out which one works best ![]()
Understood, I’ll try to be patient. ![]()
If you post between each test… so we have a timestamp… then we can align each test with our router graphs ![]()
Edit: of all the times for Th3Van’s setup to be b0rked: his graphs would have given you a great general-idea-of-how-100+nodes-perform.
bestofn with n=2 was a bit better. I have seen 60MBit/s on my storage node for a few minutes. We could maybe increase n and see how that works.
Up next choiceofn with n=4 (API pods are currently restarting. Test should start in about 10 minutes.
One data point for you, the second test (I think that would be bestofn with n=2 (whatever that means)) saw about a 10%-15% increase in downstream throughput across all my IPs without a significant increase in CPU or IOWait.
As far as I can tell, the previous one was better, as @ACarneiro said.
45-75Mbps right now for me
It still is bestofn. I can’t get choiceofn to work. I will try to figure it out in the background. In the meantime lets try bestofn n=4
Whooooa! That pretty much doubled my throughput.
Not sure what it’s doing for the success rate, mind you…
EDIT: Interestingly, for the first time during this stress test, not all IPs had a similar increase in traffic.
As far as load goes, everything seems normal on my end. Yea a bit higher RAM usage, but all within reasonable limits. Buffers + cache still good to go. I think the nodes are saying they can handle more than this
Same here. The only node I have with a higher IOWait at the moment is one of my Pi5s with spinning rust and I suspect it’s running a GC. All others are taking this in their stride.
