This was a concern in the past already: Do full nodes get vetted? - #5 by jammerdan
With SLC hammering nodes⦠is it interfering with US1 repairs? 36 is No Bueno for data customers are paying forā¦
Our devops team is already aware of this issue, but thanks for pointing it out.
According to the Community Forum Code of Conduct Code of Conduct this post is your first offense warning under the Hateful Conduct and Harassment clause due to your choice of language.
Please take care to communicate in an appropriate manner when expressing your thoughts in the Forum
Hence why I had to infer why he posted it as a solution to the large GC run I was seeing.
SNOs who have 50+ nodes and 100+ TB of data can already afford to have normal router, it is not so expensive at all
You donāt need fancy router.
My asus ac3100 was able to handle the 500mb/s without any problem.
Will be upgrading to 1gb or 2gb (will need new router) down the line if this becomes the new normal.
Thatās the key here. Itās much easier to replace routers with more ram, than to move to entirely separate infrastructure and essentially build parallel internet.
And I donāt think that memory requirements are drastically different ā stateful firewall still needs to keep track of pretty much the same amount of data.
IPv6 indeed should have been designed with built-in interoperation with ipv4. It wasnāt, and thatās why ipv4 stays.
I use Pfsense. Itās free and can handle everything with ease.
So good gear donāt have to be expensive
I donāt get the router argument. For stupid lock in reasons I am using my consumer ISP router in conjunction with a consumer Asus router and both held up just fine dealing with these tests, despite getting the traffic from 6 /24ās. This is not exactly the most efficient setup and yet, Iāve seen no issues.
NAT is not a issue at all.
This!
just buy a fast 4-8 cores with 3 ghz + and you pull over 10-20gigs pure l3 with ease. Lets drop the network discussion. Its not an issue, crazy load will however shorten the lifespan and aloy of deletion of small files combined with high ingress of files. Will be hard on spinning disk so that something everyone needs to take into account.
Hi,
So I am a 3 week old SNO, running enterprise gear that runs 24/7, so allocated space to the project. Like others, have seen a huge amount of traffic as a result of the testing.
As I said, pretty new to this, but just wanted to understand what this report is telling me in light of these changes. I was seeing small increasing storage each day, before ingress picked up on the 4th July.
But can someone help me understand the rational on these numbers, maybe I am missing something here. So for all the 3.4TB of ingress, 1.7TB stored, that nearly all of it went to garbage after being stored for a short time - for which no payment is due? Not paid for ingress, and not paid on short lived storage either. Have I interpretted that correctly?
REPORTED BY TYPE METRIC PRICE DISK BANDWIDTH PAYOUT
Node Ingress Upload -not paid- 3.45 TB
Node Ingress Upload Repair -not paid- 0.00 B
Node Egress Download $ 2.00 / TB (avg) 10.51 GB $ 0.02
Node Egress Download Repair $ 2.00 / TB (avg) 191.85 MB $ 0.00
Node Egress Download Audit $ 2.00 / TB (avg) 76.03 KB $ 0.00
Node Storage Disk Current Total -not paid- 1.69 TB
Node Storage ā Blobs -not paid- 1.65 TB
Node Storage ā Trash ā -not paid- 36.96 GB
Node+Sat. Calc. Storage Uncollected Garbage ⤠-not paid- 1.23 TB
Node+Sat. Calc. Storage Total Unpaid Data <āā -not paid- 1.27 TB
Satellite Storage Disk Last Report -not paid- 423.63 GB
Satellite Storage Disk Average So Far -not paid- 203.00 GB
Satellite Storage Disk Usage Month $ 1.49 / TBm (avg) 33.41 GBm $ 0.05
Thanks CC
All data, either normal or TTL, is paid proportionally. If you store something for a day, you get 1/30 of the monthās payout for it.
Not exactly. if you have a multinodes system that works great under 1gbit average before tests⦠than you push it to 5/10gbit limit. If you had āconsumerā router you reached 50.000maximum connection or other limits (qhora and similar router). So you forced to upgrade to 1/2k usd router family or just build a DIY pfsense⦠btw. you forced to fix a problem.
Iām happy with this⦠I was forced to evolve myself and my network knownledge
This is fine? This shows on all nodes.
But who does 10gbit on a consumer router, is there any consumer routers for 10gig besides maybe unifi?
Same here on all my 60 nodes.
Its fine, just means that a satellite (in this case it seems to be US1) hasnt been able to push avg usage stats to nodes for those days. Actual payout should be unaffected.
Like this?
