i have edited the config.yaml to increase the bandwidth amount, restarted the node but the new setting is not updated in the dashboard ? what am i doing wrong ?
You should did folowing steps:
docker stop storagenode -t 300
docker rm storagenode
- edit bandwith on your
docker run....
command and run it
