ryanw
July 18, 2019, 8:29pm
1
I can’t figure out the correct syntax to use for the new run command.
This is my old with “-v”:
docker run -d --restart unless-stopped -p 28967:28967 -e WALLET="0x1a529dd8ee6bcd5a9fa53887048c5d7b3df8329c" -e EMAIL="xxxx@xxxxx.net" -e ADDRESS="xxxxx.ddns.net:28967" -e BANDWIDTH="100TB" -e STORAGE="5.4TB" -v H:\\Identity\\storagenode\\:/app/identity -v H:\\node1\\:/app/config --name storagenode storjlabs/storagenode:alpha
I am trying to use this with “–mount”:
docker run -d --restart unless-stopped -p 28967:28967 -e WALLET="0x1a529dd8ee6bcd5a9fa53887048c5d7b3df8329c" -e EMAIL="ryan@getburst.net" -e ADDRESS="getburst.ddns.net:28967" -e BANDWIDTH="100TB" -e STORAGE="5.4TB" --mount type=bind,source="<identity-dir>",destination=H:\\Identity\\storagenode\\ --mount type=bind,source="<storage-dir>",destination=H:\\node1\\ --name storagenode storjlabs/storagenode:alpha
But I get the error Error response from daemon: invalid mount config for type “bind”: invalid mount path: ‘H://Identity//storagenode//’ mount path must be absolute.
Please advise.
Alexey
July 18, 2019, 8:54pm
2
Hello @ryanw ,
You should replace only parameters between quotes, i.e. "<storage-dir>"
to "H:\\node1\\"
, "<identity-dir>"
to "H:\\Identity\\storagenode\\"
So, the full command:
docker run -d --restart unless-stopped -p 28967:28967 -e WALLET="0x1a529dd8ee6bcd5a9fa53887048c5d7b3df8329c" -e EMAIL="ryan@getburst.net" -e ADDRESS="getburst.ddns.net:28967" -e BANDWIDTH="100TB" -e STORAGE="5.4TB" --mount type=bind,source=H:\Identity\storagenode\,destination=/app/identity --mount type=bind,source=H:\node1\,destination=/app/config --name storagenode storjlabs/storagenode:alpha
ryanw
July 18, 2019, 8:57pm
3
Wow, I feel like an idiot. Can I start the day over?
Thanks
ryanw
July 18, 2019, 9:03pm
4
It looks like the dashboard is reporting different numbers now. I was ~300MB storage used before restarting, By the way @Alexey thank you for the welcome.
Alexey
July 18, 2019, 9:08pm
5
Try in the Powershell:
"{0:N2} MB" -f ((Get-ChildItem h:/node1 -Recurse | Measure-Object -Property Length -Sum -ErrorAction Stop).Sum / 1MB)
ryanw
July 18, 2019, 9:13pm
6
6,825.89 MB
I do not have that much real capacity.
Alexey
July 18, 2019, 9:16pm
7
6GB? I think you have, otherwise node wouldn’t start. It requires at least 500GB free
ryanw
July 18, 2019, 9:18pm
8
Sorry, like I said, I need to start the day over. Or perhaps not be watching screaming kids while doing this.
What is this sum?
Alexey
July 18, 2019, 9:23pm
9
Used space by your h:\node1
folder. The info.db
can see only 1.7GB
from it.
I hope you allocated only 90% of the available space, otherwise it can overuse it.
ryanw
July 18, 2019, 9:25pm
10
Good to know, thanks. I should decrease it? It hasn’t reached even close to filling up the drive yet.
Also, is this an issue that the info.db can only see a portion of the used space?
Alexey
July 18, 2019, 9:44pm
11
This is alpha. It’s have a bugs. Better to worry than sorry
The info.db keep only track of saved and paid pieces. The Dashboard shows only the result of the info.db. The size of the info.db itself or other files on disk like files from os are not counted from the storage node yet. Allocating only 90% is a great approach, and you can’t change it every time.
