nginx: [emerg] a duplicate default server for 0.0.0.0:80 in /etc/nginx/sites-enabled/default:137
Okay … it’s working now … Had remove default_server …
Previously I was using https for proxy pass…
I’ve generated a share link from MinIo dashboard …
Which is … https://cdn.nixorigin.one/nixone/public/m/_v2/500703548553293836/a48ad3dc0-89cf68/TRjdjeyXvCQj/zDeeOjjaKNKyIINlZVcRCH5CoOBJpOtnphfysgAs.jpg?Content-Disposition=attachment%3B%20filename%3D"public%2Fm%2F_v2%2F500703548553293836%2Fa48ad3dc0-89cf68%2FTRjdjeyXvCQj%2FzDeeOjjaKNKyIINlZVcRCH5CoOBJpOtnphfysgAs.jpg"&X-Amz-Algorithm=AWS4-HMAC-SHA256&X-Amz-Credential=P4id2MjwQLioEWjNeASQBTjWdKP%2F20221127%2F%2Fs3%2Faws4_request&X-Amz-Date=20221127T135958Z&X-Amz-Expires=432000&X-Amz-SignedHeaders=host&X-Amz-Signature=75fa871b70254ba3a022abc7504987d191ad6dad808e7597cfeea88a05f85c22 …
After visiting the url … I get following
Anything wrong with my setup ? Btw , I can’t upload anything from Pixelfed …
I’ve already tried with Aws URL … but no luck
NB : I uploaded files directly from MinIo dashboard… … Still getting same error
Please update your location section to modify headers for presigned URLs: Set up Nginx proxy with MinIO Server — MinIO Object Storage for Linux,
location / {
proxy_set_header X-Real-IP $remote_addr;
proxy_set_header X-Forwarded-For $proxy_add_x_forwarded_for;
proxy_set_header X-Forwarded-Proto $scheme;
proxy_set_header Host $http_host;
proxy_connect_timeout 300;
# Default is HTTP/1, keepalive is only enabled in HTTP/1.1
proxy_http_version 1.1;
proxy_set_header Connection "";
chunked_transfer_encoding off;
proxy_pass http://0.0.0.0:7777;
You may also find a useful recommendations there.
Okay
… It’s working … Now I can Upload photos … but not getting any preview …
Dansup (Daniel) is the main developer of Pixelfed …
Also If this visit this url
It’s Redirecting me to MinIO dashboard… Which it shouldn’t
Losing my mind now … ![]()
I need to set the bucket public … right ?
You need to run GatewayST in website mode, see Gateway ST Advanced Usage - Storj DCS Docs
Is there any problem if I run with default access grant ?
Okay … Now I can access direct links … But suddenly my site isn’t responding
… Server is up and running
