VPN port forwarding for Pi nodes?
You need to provide it as an command line option after the image name, i.e.
storjlabs/storagenode:latest \
--server.address=10.66.66.2:28967
Sorry to resurrect this thread, but I recently had to manually update my Storj node because watchtower wasn’t working for some reason. When I was starting my node back up again, I attempted to add the server address as a command line option like so:
docker run -d --restart always --stop-timeout 300 \
-p 28967:28967/tcp \
-p 28967:28967/udp \
-p 14002:14002 \
-e WALLET="[REDACTED]" \
-e EMAIL="[REDACTED]" \
-e ADDRESS="[REDACTED]" \
-e STORAGE="18TB" \
--log-opt max-size=50m \
--log-opt max-file=10 \
--mount type=bind,source=/mnt/storj/identity/storagenode,destination=/app/identity \
--mount type=bind,source=/mnt/storj/storagenode,destination=/app/config \
--name storagenode storjlabs/storagenode:latest \
Was this the correct way to add the server address as a command line option? I did not receive any errors from Docker when I ran this command, but the storagenode docker container began repeatedly restarting itself every 10 seconds again. When I removed the server address line and executed the docker run command again, the node began working, just with misconfigured QUIC.
Yes, however
This address must belong to the one of the network interfaces inside the container. Usually this option is used without an IP, like --server.address=:28967 which is equivalent of --server.address=0.0.0.0:28967, so it would bind to the all network interfaces available in the container.
You may see which ones are available, when you exec to the container and call ip addr or netstat -i (these commands need to be installed with the apt install command, for netstat you need to install net-tools, for ip you need to install iproute2 package).
Hi, out of curiosity how did you set up the pi hosting storj to bypass the pi-hole’s adlist? I would consider doing the same
