Since this morning, my dashboard notice me that a new version is available.
I have setup watchtower :
# docker ps -a
770f85d981e0 storjlabs/storagenode:beta “/entrypoint” 3 days ago Up 3 days 0.0.0.0:14002->14002/tcp, 0.0.0.0:28967->28967/tcp storagenode
18b87b9c29cf storjlabs/watchtower “/watchtower storage…” 2 weeks ago Up 4 days watchtower
Interval at which watchtower checks for updates can be easily changed, modifying last parameter in: docker run -d --restart=always --name watchtower -v /var/run/docker.sock:/var/run/docker.sock storjlabs/watchtower storagenode watchtower --stop-timeout 300s --interval 21600
If watchtower ignore – interval 21600 parameter and check randomly between 12 and 72 hours, this behavior explain why my node was still running on 0.35.3
In my opinion the notification is being pushed to the node too soon. It should really only be notifying you if you are beyond the standard 3-day window.
