What the version of the binary?
storagenode version
storagenode version
Release build
Version: v0.35.3
Build timestamp: 18 Mar 20 04:23 PDT
Git commit: 6f4463f1dc22d508b2262d1bdef8caa7a5e9c156
Just checked the logs also and it’s just full of lines saying deleted with the occasional uploaded. Bandwidth has dropped off no almost nothing. Ingress this month is 539 GB but used space is only 120 GB. Not sure if that’s normal or not but CLI dashboard still says online.
Yes, it’s normal. I created an issue for bug with web dashboard
@MattJE96011 Please test the latest release version: https://github.com/storj/storj/releases/tag/v1.0.1
That should solve the issue hopefully.
No change, web dashboard remains the same. Is there any way this could be a problem on my end?
Please try to update the page by Ctrl-F5
Have you updated the storagenode to v1.0.1?
Yes, updated to v1.0.1 and still have the same result even after Ctrl-F5.
Dashboard randomly just started working all of a sudden after a manual restart. No update or config changes of any kind, just a restart of the node. No idea how or why but figured I’d let you know.
I installed the freeBSD, and installed the storagenode on it.
It’s online.
I have used the Chrome and ssh port forwarding from freeBSD to the local PC
ssh -L 14005:localhost:14002 alexey@freebsd
