Weird behavior around nodes
I was following that tutorial Step 1. Understand Prerequisites - Storj Docs
That says minimum 3 down 1 up, recommended 5 down 3 up.
I’m using commercial router, there are no problems with overwhelming.
I didn’t notice on router more than 30mb download and 11mb upload. So I think the problem is not there.
I know that I read whole tutorial from this site:
Step 1. Understand Prerequisites - Storj Docs :slight_smile:
Perhaps for someone but I have my own weirdness and I like to store thinks in one place to have better “view” on them to not make mistake.
I’m gonna try that.
From other hand I think I’m gonna nuke that few problematic nodes and make that disks RaidZ to see if there maybe is problem with disks but I can’t see anything wrong in smart or speed test. :thinking:
I figure that that’s what you meant, I tried to hint to you that bandwidth is irrelevant. Only IOPS matter. HDD can sustain about 200 IOPS. Stroj writes a lot of 16k files. 16k*200 = 3.2Mbps with no overhead. That’s the theoretical limit of your HDD. In reality you have metadata to update, and some files are m much smaller.
Because there is no activity on saltlike. It’s a test satellite.
Turn it off and check if anything changes.
You have a view of what microtik considered blocked by design. What else is dropped accidentally you don’t see.
20% of what? CPU utilization? Irrelevant. Memory consumption? Irrelevant. Number of connections it tracks at one time? Maybe relevant.
Again you are conflating iops and bandwidth. 10MB transferred in one session vs 10MB transferred in 10000 sessions 1000 bytes each has vastly different effect and performance requirements.
You claimed that you are IT twice already but I’m baffled I have to explain these basics to you.
Run the buffebloat test. It’s going to be faster than arguing why you should not do it. Confirm you get an A so we can rule this out and move on to other suspects.
Let me get this straight. You have a problem. Then you explain away and reject every suggestion without testing. What’s your plan?
Why don’t you check IOPS as suggested in the very beginning instead of randomly messing with system?
Again. Throughput vs latency. NOT the same thing.
don’t use any kind of RAID
This is pretty funny stuff guys, thanks for the entertainment.
If you don’t marinate your meat in a plastic bag, chew think too highly of yourself!
Seriously, backtrack - reconsider your opinions with that have been proposed here.
A raid Z would just server to conflate and bias read vs. write problems, and be entirely useless - not an option. If you want to ignore it, and that’s your style… maybe raid 10 it… lol, money to burn! Woot.
Is it possible that you made a mess of 7 and it made a mess on the other nodes?
Edit oops remove language
