My node is about two months old, and I noticed that my garbage volume is constantly growing, and at some huge pace. Two weeks ago it was about 29 GB, and today it is already 52 GB.
The connection is stable, there have been no breaks and downtime in the last 3 weeks, but the garbage has grown almost 2 times.
Trashed items will/should get deleted after 7 days in the trash folder. So maybe you will see some changes then.
If you want you can check the files and folders inside of the trash folder on your node if they have timestamps much older than 7 days. Normally they shouldn’t which means everything is running fine.
you could be unlucky and start at a time when 90% of uploads for a month is deleted the month after… but that would be unlikely…
the less data you have the more erratic the numbers will be…
and even later it will be anywhere between near 0 and 10% of trash i would consider normal…
that being said, there is something about files not being accepted by a node quickly enough which might lead to trash…
however deletions seems to have been higher than usual… so people should expect to see more trash for the next week or so…
there will always be trash after a certain size… even if it can get very low at times or vice versa
Older files have been already deleted, while new files were moved into trash in the meantime.
My nodes have anywhere between close to zero trash (nodes that are full for a long time, apparently mostly storing long-term data that customers just don’t want to delete) to ~60GB (fresh nodes).
