When will "Uncollected Garbage" be deleted?
According to Grafana I am moving pieces to trash at a peak effective rate of 2Gbps for the past 12 or so hours. Have accumulated ~14TB of trash so far, you love to see it.
Congratulations in solving the problem of SLC TTL data not being deleted! I currently have 3.61TB of trash showing on a 16.81 TB node. This is a great start in cleaning things up to make room for some paying data. The only question I have is why this data didn’t just get deleted directly? It is not like it needs to hang around a week in the trash for “safety” reasons like paid data. It was supposed to be automatically deleted TTL data anyway and should have immediately been irradicated. Now it is hanging around for another week before really getting deleted. Just a thought for further improvement in the process. Thank You!
Do you see a high CPU usage? The new BF from Saltlake could be more efficient than before and can move to the trash almost all expired data, which were missing in the TTL database.
Hello @NPrincen,
Because it was not registered in the storagenode TTL database when this data was uploaded to your node. This problem should be fixed with this change:
With other changes, this orphaned expired TTL data should now be collected by GC regardless of how quickly TTL records are removed from databases on the satellite side.
Does this mean that TTL collector deletions do not update the cache?
If so, this sounds like it might be a bug as the cache would ideally be updated whenever a TTL piece is deleted to avoid unnecessary records in the cache and avoid additional IOPS (trying to delete cached files that have been deleted by the collector instead of retain).
What kind of cache? Your node executes a TTL collector every hour by default, which removes expired pieces directly.
When your node receives a Bloom Filter from the satellite, it start collecting pieces, which should not exist accordingly to this BF and then retain process moves them to the trash. So, to the moment when the retain would try to move the piece, the TTL collector may remove it already.
You may also see a reverse situation, when the GC will be quicker than a TTL collector, then the TTL collector would complain about the missing piece. This usually happen if the customer deleted the TTL data before its expiration.
These two filewalkers are independent of each other, so they do not interact with each other to avoid slowing each other down. They also do two different things, the TTL collector removes pieces, the GC+retain moves pieces to the trash.
Finally!
Hello fellow Storlings,
i have 20,8GB Trash now :wink:
Now we need more Customer Data :innocent:
Greetings from Germany
Michael
I might be wrong here, since Im just assuming, but this sounds like the kind of error the badger cache might be producing if TTL deletions are not removed from it.
@edo In the node where you received those errors, did you have the badger cache enabled?
Edit: It appears that the badger cache was not enabled, so what I thought was broken would no longer be the case. I still wonder how it can be the case that retain attempts to delete data that has been deleted by TTL, as if the files are deleted the retain file walker should not find it in the system. One possible cause is that TTL is able to delete files from trash. GC may have moved it to trash, TTL deleted it from there, and then after a week they could not delete the file from trash because TTL took care of it. I am not familiar enough with the logs to know if failed to trash piece refers to moving the file to trash, or deleting it from trash.
I’m not worried, my used space is now below the satellite report and my guess of 5 TB was too low
Hi @pasatmalo, no, I didn’t have badger cache enabled on that node.
In this moment i have 30 TB of Trash on 200TB allocate. It’s ok and the nodes run perfectly. Thanks
Ps. Now i’m wait the data from clients now. :wink:
Its working perfectly right now. The cleanup takes really long to get the trash from the past months, but it gets there eventually. Its Still increasing about 20Gb every 10 mins. Lets look how long this will take.
Thank you StorJ Devs for fixing this error. You are doing a really great job.
Some round of applause for you
I can confirm it working now, but due to the amount of uncollected garbage. Some of my node, it work slowly:
# this is about 18h of running, it only get to ck dir yet (it run alphabetically)
# I estimate it would take a week a so to complete this bloom filter
saltlake.tardigrade.io:7777 (GC @ Folder:ck Date:2024-08-19)
But, much appreciate! Thank you for working on this!
Pretty simple, these are two independent processes. The TTL collector deletes pieces from the filesystem and their records from the TTL database.
The garbage collector+retain consist of two parts: the garbage collector which processing pieces accordingly to the sent Bloom Filter and remembers which pieces should be moved to the trash (in the private RAM allocation, it’s not the cache). Then it run a retain process after some amount of collected pieces (1,000 by default, --collector.expiration-batch-size). But at this time the remembered piece could be already deleted by a TTL collector.
no. If the TTL collector wouldn’t find a piece, it will print a WARN message, that the “file is not found” and go further. This is often may happen, if the customer deleted the TTL data before the expiration date. In this case it will be moved to the trash by the GC, but the TTL database will not be updated (and we likely will not change that, otherwise we would get a “database is locked” error, because this database could be opened by the TTL collector already, SQLite does not allow simultaneous access from different processes). So when the record in the TTL database will pass the expiration date, the TTL collector would try to delete this piece directly and then removes the record from the database. WARN is not considered as an error, so the record will be removed in that case too (to do not have orphaned records).
Interesting development…negative uncollected garbage?
This can happen when data has expired and was cleaned up locally after the last report from the satellite came in. Satellites only report about once a day, so that stat might be a little behind, causing this small mismatch. As long as the number is relatively low (positive or negative) you shouldn’t worry about it.
My nodes regained a lot of garbage space as well. Garbage collection has finished on all of them and i still have about a 1TB of uncollected garbage at the moment on one of my bigger nodes. Since the bigger node had 10TB of trash added this seems to be in line with the 90% accuracy rate of the bloom filters. Is anyone else seeing a 90% garbage collection rate? I am wondering if this is the bloom filter missing some of the data or if the garbage data is from something else prior to the TTL data, the node is over 2 years old. Now that this major issue has been resolved to a usable level, i am planning on continuing to grow my nodes as they fill. Thanks devs for fixing this major issue.
Untitled
How did your GC already finish? My 14TB node with an expected 10TB uncollected trash is at folder f6 (192 folders out of 1024) right now.
At that speed the trash cleanup will start before the GC finished.
So far i have 55 TB cleaned from 370TB
