After uplink setup, it appears my 1) API key and 2) secret are stored somewhere. Where is that somewhere?
On Linux, I find ~/.local/share/storj/uplink/config.yaml but nothing in it looks like it … except maybe scope? If so, how does this very long value relate to what I entered?
I’m asking because I like to know which files I need to protect / backup / …
The scope is what you are looking for. It contains the URL to satellite, the API key and encryption key.
Now we call it access string
You can decrypt it:
./uplink access inspect <here your access string>
Also, you can make an own access string for the bucket
./uplink share --readonly sj://test
Will produce the access string for read only access to the sj://test bucket
