jajaja ya también borro las entradas de la comunidad!
yo justo había posteado un reclamo ahí mismo hace días
hola entonces no vale la pena esto del storj? acabo de comprar proce placa fuente y ssd por 150 euros porque no tengo otro pc. que hago porque por si acaso descargue dos videos donde explicaba lo de storj y ahora no se si hacer lo que dice de instalar la iso que tambien la tengo o seguir otro tutorial o que. no me gusta pedir pero ayuda pliss.
Everything you need is available on documentation.storj.io. The instructions there are always up to date. I would not advise following any other instructions.
In my opinion it’s still very much worth it, but if you want to make good money you have to share a decent amount of space.
Use this estimator to see how much you may earn.
And please be careful spending too much money up front. It’s better to get a feel of how much you can earn first. An SSD is not going to help you much, better to get more space on an HDD for the same money.
This is why these videos bother me. It’s not that Storj is not worth it. It definitely is. It’s just not a get rich quick scheme. You get fair compensation for the service offered. This also means overspending is a really bad idea as it would take way too long to earn it back. So use the link I posted to get a good idea of what earnings could be, then decide what you think is worth investing. But keep in mind that even that is an estimator and there is never a guarantee that network activity remains the same.
Also we have a big storj community, I’m sure that they’d be happy to help if you run into a problem installing your node. Even though the installation on windows might seem easier if you’re not familiar with Linux I’d suggest running the nodes on some Linux distribution (I’m using Ubuntu 18.04 and it works like a charm) as it seems (from what I’ve seen on the forums so far) to be a bit more stable once it’s setup. Windows has a tendency to do weird stuff such as rebooting automatically from time to time.
vale la pena si sabes como hacerlo, Asaltador vendió el proyecto prometiendo ganancias irreales.
Tienes que ponerte a leer la documentación del proyecto y decidir si vale o no la pena para ti.
ok t im new in all of these. i hope it work good thanks
pues espero que salga con buenas explicaciones pero vamos no digo que me caiga mal de hecho me caia muy bien y mas de estos videos pero ahora que los ha borrado es desilusionante por muchas excusas que ponga luego
Llevo es las sombras leyendo este foro desde marzo, siguiendo este hilo desde el minuto uno.
Yo ya sabia que esto terminaria pasando…
Conozco Storj desde 2017 pero nunca me habia animado a montar un nodo hasta este marzo
Al de hardwaresfera lo conozco por ser un cantamañanas y un analfabeto de IT y esta jugarreta del photoshop con el dashboard y las ganancias de Storj me lo ha acabado de confirmar.
Que os entre en la cabeza que esto lo ha hecho por los enlaces de afiliado de Coolmod y para ganarse unos miserables euros
El excel de BrightSilence de la calculadora de ganancias es realista y se va cumpliendo
Hay que ser muy ingenuo para creerse que alguien pagaria 400€ por un googledrive de 1TB al mes cuando microsoft vende su onedrive de 1TB por 5€ al mes
Saludos y animo a todos esos que se sientan estafados, aqui hay negocio pero como ya han dicho no te haras rico en dos meses
