As of the beginning of March my node has has 0 bytes Ingress and seems to be artificially capped at exactly 1TB for reasons I don’t know. There is 7TB available disk total, the dashboard reports 6TB disk remaining.
About 3 months ago my disk usage was up to about 2.1TB until overnight it just reduced suddenly to 1TB where it has been hovering around until March where Ingress totally stopped.
I can’t think of any reason why this would be happening.
Welcome to the forum @shadeygnome!
Can you show last 20 lines of your log ?
2020-03-17T02:04:09.710Z INFO piecestore download started {"Piece ID": "Y3V6TGGTXOK5LEPZ2EIHIY6YCSR3LJO2EGE56M73P2XCZWWX5Y2A", "Satellite ID": "118UWpMCHzs6CvSgWd9BfFVjw5K9pZbJjkfZJexMtSkmKxvvAW", "Action": "GET_REPAIR"}
2020-03-17T02:04:10.032Z INFO piecestore download started {"Piece ID": "7R34YZHWSD5RCA7SSERDCA7PMZ4KRBZ4VLQHDVLLJD4ERYLPORVQ", "Satellite ID": "118UWpMCHzs6CvSgWd9BfFVjw5K9pZbJjkfZJexMtSkmKxvvAW", "Action": "GET"}
2020-03-17T02:04:12.394Z INFO piecestore downloaded {"Piece ID": "Y3V6TGGTXOK5LEPZ2EIHIY6YCSR3LJO2EGE56M73P2XCZWWX5Y2A", "Satellite ID": "118UWpMCHzs6CvSgWd9BfFVjw5K9pZbJjkfZJexMtSkmKxvvAW", "Action": "GET_REPAIR"}
2020-03-17T02:04:13.283Z INFO piecestore download failed {"Piece ID": "7R34YZHWSD5RCA7SSERDCA7PMZ4KRBZ4VLQHDVLLJD4ERYLPORVQ", "Satellite ID": "118UWpMCHzs6CvSgWd9BfFVjw5K9pZbJjkfZJexMtSkmKxvvAW", "Action": "GET", "error": "rpc error: code = Canceled desc = context canceled", "errorVerbose": "rpc error: code = Canceled desc = context canceled\n\tstorj.io/common/rpc/rpcstatus.Wrap:79\n\tstorj.io/storj/storagenode/piecestore.(*Endpoint).doDownload.func5:674\n\tgolang.org/x/sync/errgroup.(*Group).Go.func1:57"}
2020-03-17T02:04:13.283Z ERROR server gRPC stream error response {"error": "rpc error: code = Canceled desc = context canceled", "errorVerbose": "rpc error: code = Canceled desc = context canceled\n\tstorj.io/common/rpc/rpcstatus.Wrap:79\n\tstorj.io/storj/storagenode/piecestore.(*Endpoint).doDownload.func5:674\n\tgolang.org/x/sync/errgroup.(*Group).Go.func1:57"}
2020-03-17T02:04:25.498Z INFO piecestore deleted {"Satellite ID": "12L9ZFwhzVpuEKMUNUqkaTLGzwY9G24tbiigLiXpmZWKwmcNDDs", "Piece ID": "WRXTL4DQIYB22H5RPYQKTXFJU3WENMDKUV67N2D2CARNVAIKG6IQ"}
2020-03-17T02:04:32.226Z INFO piecestore deleted {"Satellite ID": "12L9ZFwhzVpuEKMUNUqkaTLGzwY9G24tbiigLiXpmZWKwmcNDDs", "Piece ID": "6CTWLCQRCH7FBE66ABDXWSM6GSZIKOEO5355ONFOUCPQUAVWTSLQ"}
2020-03-17T02:04:54.202Z INFO piecestore deleted {"Satellite ID": "12L9ZFwhzVpuEKMUNUqkaTLGzwY9G24tbiigLiXpmZWKwmcNDDs", "Piece ID": "6CA4AEDDOJMSUSPUVNILETEPMUBWTPZ6O7XW7YUMCJIOHTRHDVDQ"}
2020-03-17T02:04:56.445Z INFO piecestore deleted {"Satellite ID": "12L9ZFwhzVpuEKMUNUqkaTLGzwY9G24tbiigLiXpmZWKwmcNDDs", "Piece ID": "RRTRIXMHVOCQLAGRTVAMBDFUWVUG6ELXZVWFBI2PYNGVLBFBCH2Q"}
2020-03-17T02:05:23.979Z INFO piecestore deleted {"Satellite ID": "12L9ZFwhzVpuEKMUNUqkaTLGzwY9G24tbiigLiXpmZWKwmcNDDs", "Piece ID": "QFRWAML42PRWVRZ2JD2Y4DT5TP4UPVYGVQOPLBEKL5PQW47D5TNQ"}
2020-03-17T02:05:37.277Z INFO piecestore deleted {"Satellite ID": "12L9ZFwhzVpuEKMUNUqkaTLGzwY9G24tbiigLiXpmZWKwmcNDDs", "Piece ID": "PKDBOQ7WKCPDMZU7SNWPP52V3TPZDNNFAC25DASC7U5DCINYSURA"}
2020-03-17T02:05:39.070Z INFO piecestore download started {"Piece ID": "HY7ULMCPDK4EECVEASFXFDJ4J42JPLZZJH6KY6O5KVKZVTND772A", "Satellite ID": "12EayRS2V1kEsWESU9QMRseFhdxYxKicsiFmxrsLZHeLUtdps3S", "Action": "GET_AUDIT"}
2020-03-17T02:05:39.312Z INFO piecestore downloaded {"Piece ID": "HY7ULMCPDK4EECVEASFXFDJ4J42JPLZZJH6KY6O5KVKZVTND772A", "Satellite ID": "12EayRS2V1kEsWESU9QMRseFhdxYxKicsiFmxrsLZHeLUtdps3S", "Action": "GET_AUDIT"}
2020-03-17T02:06:18.194Z INFO piecestore deleted {"Satellite ID": "12L9ZFwhzVpuEKMUNUqkaTLGzwY9G24tbiigLiXpmZWKwmcNDDs", "Piece ID": "62WCEZVLPOARNSRKUR6ZISLTN3XKIS3YEVSYG7LRXA5MRUURMS5A"}
2020-03-17T02:07:01.311Z INFO piecestore download started {"Piece ID": "W2NDBEJQFFVIQKSZXZG7DKN54XABLR363FQH4JQ4ZNW7DYMQGK6Q", "Satellite ID": "118UWpMCHzs6CvSgWd9BfFVjw5K9pZbJjkfZJexMtSkmKxvvAW", "Action": "GET_REPAIR"}
2020-03-17T02:07:08.936Z INFO piecestore downloaded {"Piece ID": "W2NDBEJQFFVIQKSZXZG7DKN54XABLR363FQH4JQ4ZNW7DYMQGK6Q", "Satellite ID": "118UWpMCHzs6CvSgWd9BfFVjw5K9pZbJjkfZJexMtSkmKxvvAW", "Action": "GET_REPAIR"}
2020-03-17T02:07:10.168Z INFO bandwidth Performing bandwidth usage rollups
2020-03-17T02:07:11.579Z INFO version running on version v0.31.12
2020-03-17T02:07:23.153Z INFO piecestore download started {"Piece ID": "HKGLAPJQ4U2ZKK35CCUNFSRI6W7CBCXCG2HKEHKY3S2VMUM5RVLA", "Satellite ID": "118UWpMCHzs6CvSgWd9BfFVjw5K9pZbJjkfZJexMtSkmKxvvAW", "Action": "GET_REPAIR"}
2020-03-17T02:07:27.666Z INFO piecestore downloaded {"Piece ID": "HKGLAPJQ4U2ZKK35CCUNFSRI6W7CBCXCG2HKEHKY3S2VMUM5RVLA", "Satellite ID": "118UWpMCHzs6CvSgWd9BfFVjw5K9pZbJjkfZJexMtSkmKxvvAW", "Action": "GET_REPAIR"}
Are you running Windows node using GUI ?
hi @nerdatwork
Thanks for your interest . I am running a Linux node using the ARM Docker image storjlabs/storagenode:beta
Regarding version, I just pulled a new image and it’s now 0.34.6 and immediately has started receiving data. I will keep monitoring it for now but that was probably it.
I didn’t realize that there were recent updates as I was no longer receiving the update emails for some reason! I suppose I should turn on auto-update from now on
Make sure you specified more than 1TB in your run command. Changes to this value in the config.yaml don’t work. The run command overrules that.
Check this page for more info.
https://documentation.storj.io/resources/faq/how-do-i-change-my-parameters-such-as-payout-address-allotted-storage-space-and-bandwidth
