100 GB of trash. how to clear it?
150 GB of trash. how to clear it?
:drum:
Trash gets automatically deleted after 7 days.
I am just curious, you have around 7 TB of data and this is the first time you had a question about trash.
That seems like a low amount of trash as well: on 1-2TB nodes don’t you normally see 5-10%?
He never checks his trash :sweat_smile:.
i did post before if i remember correctly, but i could not find the post nor the solution…
not sure if that is normal for that amount of trash.
Pretty normal. Sometimes we have up to 1TB or even more - depending on the customers’ activity.
Not normal, if you have errors in your logs related to trash, walk, retain or database.
