Hi all. I read somewhere that I have to run “-p 28968:28967” command instead of “28967:28967” when trying to set up my 2nd node. I’ve done this but am still not able to get my node online. Should "-e"port be 28968 or 28967? Any other insight appreciated.
So I have the router set up to fwd 28968 -->28968, then have the docker command as below. The two nodes seem to be fighting over the 28967 port still. Been playing with it and can’t figure it out… If you see anything I’ve missed please let me know
Ended up just using 28968 for everything for the 2nd node instead of 28968:28967 and it seems to be working… Not sure why it was instructing me to have 28968 changed to 28967 which is already occupied by the first node… documentation is kind of confusing
So, if -p 28968:28968 is working for you, then you changed for some reason the server.address: :28967 to server.address: :28968 too.
It’s not needed in case of docker, then the port mapping -p 28968:28967 will work.
