had several days of no power to the storage node, i am passing online status however i am in suspension currently as i am getting hammered with this error. anyway to run a job to clean up the storage or something ? or will this process out at some point ?
2024-12-02T15:29:19-05:00 ERROR piecestore download failed {“Piece ID”: “6FZTA2OPDQ6EUNZDA7KDBMM57ZGNPVKA5OP6THY3VM5EZ7IYQOGA”, “Satellite ID”: “12EayRS2V1kEsWESU9QMRseFhdxYxKicsiFmxrsLZHeLUtdps3S”, “Action”: “GET”, “Offset”: 0, “Size”: 2319104, “Remote Address”: “79.127.226.105:56052”, “error”: “pieces error: filestore error: unable to open "J:\\blobs\\ukfu6bhbboxilvt7jrwlqk7y2tapb5d2r2tsmj2sjxvw5qaaaaaa\\6f\\zta2opdq6eunzda7kdbmm57zgnpvka5op6thy3vm5ez7iyqoga.sj1": The file or directory is corrupted and unreadable.”, “errorVerbose”: “pieces error: filestore error: unable to open "J:\\blobs\\ukfu6bhbboxilvt7jrwlqk7y2tapb5d2r2tsmj2sjxvw5qaaaaaa\\6f\\zta2opdq6eunzda7kdbmm57zgnpvka5op6thy3vm5ez7iyqoga.sj1": The file or directory is corrupted and unreadable.\n\tstorj.io/storj/storagenode/blobstore/filestore.(*Dir).Open:360\n\tstorj.io/storj/storagenode/blobstore/filestore.(*blobStore).Open:118\n\tstorj.io/storj/storagenode/pieces.(*Store).Reader:323\n\tstorj.io/storj/storagenode/piecestore.(*Endpoint).Download:762\n\tstorj.io/common/pb.DRPCPiecestoreDescription.Method.func2:302\n\tstorj.io/drpc/drpcmux.(*Mux).HandleRPC:33\n\tstorj.io/common/rpc/rpctracing.(*Handler).HandleRPC:62\n\tstorj.io/common/experiment.(*Handler).HandleRPC:43\n\tstorj.io/drpc/drpcserver.(*Server).handleRPC:166\n\tstorj.io/drpc/drpcserver.(*Server).ServeOne:108\n\tstorj.io/drpc/drpcserver.(*Server).Serve.func2:156\n\tstorj.io/drpc/drpcctx.(*Tracker).track:35”}
Stop the node, run chkdsk /f j:. Then buy an UPS.
With all the NTFS fragility it’s still hard to imagine the power outage could screw it up so much. I’m wondering if there is some underlying hardware issue — such as faulty disk controller or bad ram.
No I know what the issue is. It’s a virtual box guest running on a hypervisor backed by btfrs… And that didn’t handle things very nicely. Ima let chkdsk run but I don’t have high hopes.
Why would not you run storagenode directly on the storage appliance, accessing btrfs sub volume natively? But I guess it’s a rhetorical question at this point…
Unfortunately I’m agree with @arrogantrabbit
It started as a standalone windows device and I didn’t know how to convert it to Linux,
This way:
Specifically:
