So MKdir out of the dir i am in called storjbin ill call it then put it in where storjdir is?
Yes but you need the full path you cant just put /storjdir
So how do i get the full path of where this directory i just created is ?
diamonddog@storj1:~$ mkdir storjbin
diamonddog@storj1:~$ dir
identity_linux_amd64.zip snap storjbin
You can try
echo /home/$USER
I got :
diamonddog@storj1:~$ echo /home/$USER
/home/diamonddog
So if you created storjdir in home it /home/diamonddog/storjdir
Also You can use winscp you can just copy and paste it
So put that in here
–mount type=bind,source=“/home/diamonddog/storjbin”,destination=/app/config
Yes that would be correct
Now getting error
docker: Error response from daemon: driver failed programming external connectivity on endpoint storagenode (xxxxxxxxxxxxxxxxxxx): Error starting userland proxy: listen tcp4 0.0.0.0:28967: bind: address already in use.
run docker ps do you have a another container running?
docker rm storagenode
You should be able to rerun it
Getting what looks like same error :
docker: Error response from daemon: driver failed programming external connectivity on endpoint storagenode (XXXXXXX): Error starting userland proxy: listen tcp4 0.0.0.0:28967: bind: address already in use.
Try a different port -p 28968:28967/tcp -p 28968:28967/udp
now getting this error
docker: Error response from daemon: driver failed programming external connectivity on endpoint storagenode (xxxxxxxxx): Error starting userland proxy: listen tcp4 0.0.0.0:14002: bind: address already in use.
Do you have a storagenode running on systemd?
I don’t know what that is sorry
