I am frustrated with these install instructions that make ZERO sense for Ubuntu installs.
getting errors left and right.
So if you want to make an extra $50 helping me install this Storj on my Ubuntu today then reply and we can go from there. I would need you to be able to help me TODAY asap.
Reply if you can do this. Thank you in advance.
Are you trying to setup the node with docker or without? With docker it should be pretty easy. Which Ubuntu-Version are you using?
With docker - Not as easy as one would think.
Version 22.04.1 LTS
Thats the Ubuntu server ver. i am using
ok, where exactly is the issue? Which steps were successful and which were not?
At this point I have no idea what i have set up or not. The directions have me all turned around not knowing what way is up. I got to the part where i entered the command :
-p 28967:28967/tcp
-p 28967:28967/udp
-p 14002:14002
-e WALLET=“SENSORED "
-e EMAIL=“SENSORED "
-e ADDRESS=“SENSORED "
-e STORAGE=“9TB”
–user $(id -u):$(id -g)
–mount type=bind,source=”/home/diamonddog/.local/share/storj/identity/storagenode”,destination=/app/identity
–mount type=bind,source=”/storjdir",destination=/app/config
and i get this error :
docker: Error response from daemon: invalid mount config for type “bind”: bind source path does not exist: /storjdir.
See ‘docker run --help’.
ok that means that the path that you provided does not exist on your system. Can you specify the full absolute path to the directory where you want STORJ to save its data here instead of ”/storjdir"?
Something like “/mnt/extdrive1/storj/node1” for example.
The directory DOES exist but at this point i really dont care where or what its named so I can just create a new one and if you tell me how to do that so this works that would be GREAT!
ok so it exists inside your user directory? Like “/home/diamonddog/storjdir”?
Or in the root of your filesystem?
not sure. But i did do mkdir i think in root if i am not mistaken
Can you check that with using the “ls” command? That should list all files and directories in your current cli-location.
This is all i got here
identity_linux_amd64.zip snap
sembeth
February 2, 2023, 3:49pm
13
thereverendd:
You may have a problem with permissions if you created the dir “/storjdir” as root user. But try to run the docker container as another user.
Please do an “ls -la” to list permissions.
ok, how did you mount that 9TB drive? Do you have that command?
It was already mounted its a RAID on a server
here is the output for the permissions :
diamonddog@storj1:~$ ls -la
total 10028
drwxr-x— 6 diamonddog diamonddog 4096 Jan 29 22:53 .
drwxr-xr-x 4 root root 4096 Jan 29 20:59 …
-rw------- 1 diamonddog diamonddog 8134 Feb 2 03:10 .bash_history
-rw-r–r-- 1 diamonddog diamonddog 220 Jan 6 2022 .bash_logout
-rw-r–r-- 1 diamonddog diamonddog 3771 Jan 6 2022 .bashrc
drwx------ 2 diamonddog diamonddog 4096 Jan 29 21:00 .cache
-rw-rw-r-- 1 diamonddog diamonddog 10222282 Jan 29 21:17 identity_linux_amd64.zip
drwxr–r-- 3 diamonddog diamonddog 4096 Jan 29 22:25 .local
-rw-r–r-- 1 diamonddog diamonddog 807 Jan 6 2022 .profile
drwx------ 3 diamonddog diamonddog 4096 Jan 29 22:53 snap
drwx------ 2 diamonddog diamonddog 4096 Feb 2 02:04 .ssh
-rw-r–r-- 1 diamonddog diamonddog 0 Jan 29 21:00 .sudo_as_admin_successful
If he mounted it correctly it would only be in a location for example /mnt/hd1/storjdir
You wouldnt be able to directly access it any other way…
I installed UBUNTU on the 9TB raid array and it shows when i log on
Welcome to Ubuntu 22.04.1 LTS (GNU/Linux 5.15.0-58-generic x86_64)
System information as of Thu Feb 2 03:53:00 PM UTC 2023
System load: 0.3662109375
Usage of /home: 0.0% of 9.82TB
Memory usage: 2%
Swap usage: 0%
Processes: 191
Users logged in: 0
IPv4 address for docker0: XXXX
IPv4 address for ens160: XXX
IPv6 address for ens160: XXXX
0 updates can be applied immediately.
So you booted off the 10TB drive, so you need to create a dir and point docker to that dir.
How do I do that? What are the exact commands you want me to enter to do all of that?
thereverendd:
–mount type=bind,source=”/home/diamonddog/storjdir",destination=/app/config
Kinda the same as you did with identity that for example
