I am a bit worried that there are a bunch of posts =out there= that say 64bit arm is broken and it doesn’t get fixed
What are the main platforms then?
The only issue is if you use ARM64 device with 64 bit OS, which detected as aarch64 instead of arm32v6/v7 and use a docker version of storagenode.
The workaround is to use a 32 bit arm image or wait for the next version.
Issue related to outdated and not supported upstream image…
