I went to add some StorageNode to my local test environment with my own ca file, How can I perform the “Authorize Storage Node identity” operation in this environment (storj-up)?
I think this check is disabled and you may just add a node with a new identity, but need to configure it to trust your satellite, and use the versions server from storj-up.
