I found my node encountered database malformed.
The problematic node may be disqualified because it takes too long to repair.
Can I just move the bandwidth.db file to another server(with SSD) for repair?
In addition, if there is “bandwidthdb: disk I/O error: no such file or directory” after repair, which file needs to be repaired at the same time?
On the other hand, I tried to fix the malformed database.db a long time ago.
After the repair, I use sqlite3 command to check and the result showed “ok”, but there is still a record of “database disk image is malformed” in the node log. How can I fix this problem?
