Hi,
I run the command (with my details and/or parameters):
docker run -d --restart unless-stopped --stop-timeout 300 -p 28967:28967/tcp -p 28967:28967/udp -p 127.0.0.1:14002:14002 -e WALLET=“0xXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXX” -e EMAIL="user@example.com " -e ADDRESS=“domain.ddns.net:28967 ” -e STORAGE=“2TB” --mount type=bind,source="",destination=/app/identity --mount type=bind,source="",destination=/app/config --name storagenode storjlabs/storagenode:latest
And get an access denied message. Please help.
Alexey
November 24, 2021, 8:29pm
2
Please, copy the whole error. To make it pretty formatted, please place it between two new lines with three backticks like this:
place copied text here
docker run -d --restart unless-stopped --stop-timeout 300 -p 28967:28967/tcp -p 28967:28967/udp -p 127.0.0.1:14002:14002 -e WALLET="0xMY_WALLET_ADDRESS" -e EMAIL="MY_EMAIL_ADDRESS" -e ADDRESS="MY_PUBLIC_IP_ADDRESS:28967" -e STORAGE="1TB" --mount type=bind,source=C:\Users\\***\AppData\Roaming\Storj\Identity\storagenode,destination=/app/identity --mount type=bind,source=C:\StorjNode01,destination=/app/config --name storagenode storjlabs/storagenode:latest
docker: Error response from daemon: mkdir C:\Users\abrnet: Access is denied.
Alexey
November 24, 2021, 8:50pm
4
Seems the docker doesn’t have an access to specified folder for the identity.
Please, execute this command in PowerShell:
"$env:AppData\Storj\Identity\storagenode"
and copy the result to your source=
for identity.
By the way what version of Docker desktop you have used?
The result is identical to the path I supplied previously. My docker version is 4.2.0
Alexey
November 24, 2021, 9:01pm
6
The docker tries to create a folder C:\Users\abrnet
, so you could specify it wrongly. Or maybe there are spaces in your username, if so, you need to enclose the path in quotes.
I would like to suggest to move your identity to the folder with data and use this path instead of path in AppData.
