Accidentaly create identity with same name
I want create second node, at the second node i didnt know before which don’t use same name identity
first node and second node are different vm and location
What have i done?
-I was creating second node with same email with first node but with different authorization token, so a something like this at both node user@example.com:xxxxxx are different each other
-Both node have same wallet address, i think it’s not a problem.
-I was executing identity create storagenode in first node, but i did same too in second node, i realized it’s a mistake after saw this forum because that identity name already exist (storagenode),
so i saw in second node’s log it gave me output like this
storj.io/private/process.cleanup.func1:381
        github.com/spf13/cobra.(*Command).execute:852
        github.com/spf13/cobra.(*Command).ExecuteC:960
        github.com/spf13/cobra.(*Command).Execute:897
        storj.io/private/process.ExecWithCustomConfig:88
        storj.io/private/process.ExecCustomDebug:70
        main.main:385
        runtime.main:204
2021-10-01T20:33:49.220Z        INFO    Configuration loaded    {"Location": "/app/config/config.yaml"}
2021-10-01T20:33:49.236Z        INFO    Operator email  {"Address": "ikhwanperwira@gmail.com"}
2021-10-01T20:33:49.237Z        INFO    Operator wallet {"Address": "0xF6E8d68C40886aEA1d5A73DfA47BD2AEDFE57d55"}
2021-10-01T20:33:49.243Z        INFO    db      database does not exists       {"database": "info"}
2021-10-01T20:33:49.243Z        INFO    db      database does not exists       {"database": "bandwidth"}
2021-10-01T20:33:49.243Z        INFO    db      database does not exists       {"database": "orders"}
2021-10-01T20:33:49.243Z        INFO    db      database does not exists       {"database": "piece_expiration"}
2021-10-01T20:33:49.244Z        INFO    db      database does not exists       {"database": "pieceinfo"}
2021-10-01T20:33:49.244Z        INFO    db      database does not exists       {"database": "piece_spaced_used"}
2021-10-01T20:33:49.244Z        INFO    db      database does not exists       {"database": "reputation"}
2021-10-01T20:33:49.244Z        INFO    db      database does not exists       {"database": "storage_usage"}
2021-10-01T20:33:49.244Z        INFO    db      database does not exists       {"database": "used_serial"}
2021-10-01T20:33:49.244Z        INFO    db      database does not exists       {"database": "satellites"}
2021-10-01T20:33:49.244Z        INFO    db      database does not exists       {"database": "notifications"}
2021-10-01T20:33:49.244Z        INFO    db      database does not exists       {"database": "heldamount"}
2021-10-01T20:33:49.244Z        INFO    db      database does not exists       {"database": "pricing"}
2021-10-01T20:33:49.244Z        INFO    db      database does not exists       {"database": "secret"}
Error: Error creating revocation database: revocation database: boltdb: invalid database
        storj.io/storj/storage/boltdb.New:44
        storj.io/storj/private/revocation.openDBBolt:52
        storj.io/storj/private/revocation.OpenDB:35
        storj.io/storj/private/revocation.OpenDBFromCfg:23
        main.cmdRun:169
        storj.io/private/process.cleanup.func1.4:363
        main.main:385
        runtime.main:204
i should have execute this identity create storagenode2 in second node,
so will it affect my first node?
if you moved first node identity to other place then all ok, but it you rewrited first identity then all is bad
but i saw first node’s logs everything are running normal
did you made restart? identity loading during service start only
i did sudo docker stop storagenode in first node, then sudo docker start storagenode in first node. Still working fine because logs stream still give me normal output
does nodes has unic id? if they are not same then you safe, if same then bad
they are different node id, okay thank you solved,
that output error because permission error in folder,
eventhough same name identity when creating it, doesnt mean same nodeid, luckily i have the backup identity if theres something unexpected event
