Adding disk to note in Unraid
I’d like to add a second disk to the storj node in Unraid. I’ve not had any success so far.
Config type?
Try the unassigned devices plugin and mount the additional drive.
I wouldn’t recommend expanding the space of the first node, but start a new node with the standalone drive.
I’ve got it mounted. I’d have to go through the process of installing a second storj docker instance to start a new node?
Yes, include a new identity generation.
See
