Hi, after gracefull exit is complete with all Yes and i have the receipt for all satelittes, can i stop the node? I will recevice payment of held amount next month?
Hi, yes, if your Undistributed amount would be enough to clear a Minimum Payout Threshold on the selected network (on L2 zkSync Era it would be much lower than on L1 Ethereum for example).
So, if you currently didn’t specify a zkSync Era as a wallet feature, the ability of your node to receive a payout would depends on a Minimum Payout Threshold on L1 Ethereum. Thus I would recommend to save your identity for the case if you would decide to change your mind later and receive a final payout on zkSync Era instead.
Ok, i have L1 payment but i have 30 nodes on one wallet, then the payment is over the minimum payout. I saved the id of receipt and the node id and the identity for future problems but i can think that i haven’t problems for payment next month. Thanks a lot for reply
if they finished GE before the current month has been started, you may receive an Undistributed payout this month.
I finished GE today and i received the payment for this month yesterday. Sure the payment for this GE will receive next month. Thanks
