Hello,
I have move my node on different VM, I have reconnect my ISCSI target and all was working fine except for my dashboard that doesn’t show any stat like in the pic:
If I expand the timeframe of the stats I see all my old stat until the VM migration
what I have to do to fix it ?
Solu
December 16, 2019, 1:55pm
2
Had a similar issue a few weeks ago…
Did you have rsynced your Node into a other Destination on iSCSI?
In my case i forgot to rsync with --delete option.
Take a look here:
Here the content:
total 181320
-rwxrwxrwx 1 root root 1515520 Nov 20 14:30 bandwidth.db
-rwxrwxrwx 1 root root 32768 Nov 20 14:45 bandwidth.db-shm
-rwxrwxrwx 1 root root 4177712 Nov 20 14:45 bandwidth.db-wal
drwxrwxrwx 6 root root 4096 Okt 10 00:42 blobs
-rwxrwxrwx 1 root root 36933370 Sep 30 21:41 dump_all_notrans.sql
-rwxrwxrwx 1 root root 36933416 Sep 30 21:41 dump_all.sql
drwxrwxrwx 2 root root 4096 Nov 20 14:45 garbage
-rwxrwxrwx 1 root root 8192 Okt 3 22:07 info.db
-rwxrwxrwx 1 r…
the last rsync that I have complete before the switch was with --delete; this is the content of my directory:
fabrizio@ubuntu:/mnt/storage$ ll
total 261676
drwxr-xr-x 7 root root 4096 Dec 16 15:18 ./
drwxr-xr-x 7 root root 4096 Dec 12 12:03 …/
-rw-r–r-- 1 root root 2084864 Dec 16 15:16 bandwidth.db
-rw-r–r-- 1 root root 32768 Dec 16 15:18 bandwidth.db-shm
-rw-r–r-- 1 root root 4602072 Dec 16 15:18 bandwidth.db-wal
drwxr-xr-x 2 root root 4096 Jul 16 23:56 blob/
drwxr-xr-x 6 root root 4096 Sep 6 22:34 blobs/
-rw-r–r-- 1 root root 345 Dec 10 09:25 dump_all_notrans.sql
-rw-r–r-- 1 root root 391 Dec 10 09:24 dump_all.sql
drwxr-xr-x 2 root root 4096 Dec 16 15:17 garbage/
-rw-r–r-- 1 root root 16384 Dec 10 09:26 info.db
-rw-r–r-- 1 root root 32768 Dec 13 08:51 info.db-shm
-rw-r–r-- 1 root root 0 Dec 13 08:51 info.db-wal
-rw-r–r-- 1 root root 205455360 Dec 16 15:09 orders.db
-rw-r–r-- 1 root root 32768 Dec 16 15:18 orders.db-shm
-rw-r–r-- 1 root root 9237072 Dec 16 15:18 orders.db-wal
-rw-r–r-- 1 root root 53248 Dec 12 11:56 piece_expiration.db
-rw-r–r-- 1 root root 32768 Dec 13 08:51 piece_expiration.db-shm
-rw-r–r-- 1 root root 0 Dec 13 08:51 piece_expiration.db-wal
-rw-r–r-- 1 root root 16384 Dec 10 09:26 pieceinfo.db
-rw-r–r-- 1 root root 32768 Dec 13 08:51 pieceinfo.db-shm
-rw-r–r-- 1 root root 0 Dec 13 08:51 pieceinfo.db-wal
-rw-r–r-- 1 root root 12288 Dec 13 08:46 piece_spaced_used.db
-rw-r–r-- 1 root root 32768 Dec 16 14:54 piece_spaced_used.db-shm
-rw-r–r-- 1 root root 1627432 Dec 16 14:54 piece_spaced_used.db-wal
-rw-r–r-- 1 root root 12288 Dec 13 08:46 reputation.db
-rw-r–r-- 1 root root 32768 Dec 16 12:54 reputation.db-shm
-rw-r–r-- 1 root root 659232 Dec 16 12:54 reputation.db-wal
-rw-r–r-- 1 root root 24576 Dec 10 09:26 satellites.db
-rw-r–r-- 1 root root 32768 Dec 13 08:51 satellites.db-shm
-rw-r–r-- 1 root root 0 Dec 13 08:51 satellites.db-wal
-rw-r–r-- 1 root root 12288 Dec 13 08:46 storage_usage.db
-rw-r–r-- 1 root root 32768 Dec 16 08:53 storage_usage.db-shm
-rw-r–r-- 1 root root 449112 Dec 16 08:53 storage_usage.db-wal
drwxr-xr-x 2 root root 4096 Dec 16 15:18 temp/
drwxr-xr-x 2 root root 4096 Jul 12 06:45 trash/
-rw-r–r-- 1 root root 31277056 Dec 16 15:11 used_serial.db
-rw-r–r-- 1 root root 32768 Dec 16 15:18 used_serial.db-shm
-rw-r–r-- 1 root root 12005712 Dec 16 15:18 used_serial.db-wal
Alexey
December 24, 2019, 8:16am
4
What is web dashboard show?
