I have read through as many threads as I can about offline node issues and I still can’t figure out the issue I have. I will post the error it generates in the log when it attempts to start. Any suggestions would be great. Thank you in advance! I am running this node on Windows 10 with windows GUI. This error applies to blobs, garbage, trash all of the folders it seems to use when running.
FATAL Unrecoverable error {“error”: “Error starting master database on storagenode: group:\n— CreateFile \StorJ\blobs: The system cannot find the path specified.\n— CreateFile \StorJ\temp: The system cannot find the path specified.\n— CreateFile \StorJ\garbage: The system cannot find the path specified.\n— CreateFile \StorJ\trash: The system cannot find the path specified.”, “errorVerbose”:
Hi @lewial
In the config.yaml file what is the directory listed for storage.path:? Does the directory still exist? How is the location/drive physically connected to the computer?
The logged error is odd because it should show the full path, e.g. CreateFile F:\StorJ\blobs: The system cannot find the path specified… F:\StorJ\temp…etc.
This suggests the USB drive disconnected and the drive letter changed.
I tried to post the full error but when I submit it says a new member can only post 2 links. I assume this text box is viewing the text as hyperlinks? If there’s another way I can post the entire error logged I can do that.
The drive letter hasn’t changed but I feel like my computer may have restarted when I was away.
FATAL Unrecoverable error {"error": "Error starting master database on storagenode: group:\n--- CreateFile F:\\StorJ\\blobs: The system cannot find the path specified.\n--- CreateFile F:\\StorJ\\temp: The system cannot find the path specified.\n--- CreateFile F:\\StorJ\\garbage: The system cannot find the path specified.\n--- CreateFile F:\\StorJ\\trash: The system cannot find the path specified.", "errorVerbose": "Error starting master database on storagenode: group:\n--- CreateFile F:\\StorJ\\blobs: The system cannot find the path specified.\n--- CreateFile F:\\StorJ\\temp: The system cannot find the path specified.\n--- CreateFile F:\\StorJ\\garbage: The system cannot find the path specified.\n--- CreateFile F:\\StorJ\\trash: The system cannot find the path specified.\n\tmain.cmdRun:162\n\tstorj.io/private/process.cleanup.func1.4:363\n\tstorj.io/private/process.cleanup.func1:381\n\tgithub.com/spf13/cobra.(*Command).execute:852\n\tgithub.com/spf13/cobra.(*Command).ExecuteC:960\n\tgithub.com/spf13/cobra.(*Command).Execute:897\n\tstorj.io/private/process.ExecWithCustomConfig:88\n\tstorj.io/private/process.Exec:65\n\tmain.(*service).Execute.func1:64\n\tgolang.org/x/sync/errgroup.(*Group).Go.func1:57"}
I missed a step in the ownership part after removing user and administrator rights. The owner transfer to SYSTEM is processing now. If it doesn’t work after that I will run those PowerShell commands and post the results.
