All up and running again, but received 'Disqualified' email?
I had a breakdown for several hours. Restarted and received ‘node back online’ mails and ‘monitor up’ from Uptime Robot.
Dashboard shows ‘Online OK 18h36m’, disk is working hard, but still this morning I received a ‘Disqualified Saltlake satellite’ email, saying that I need to create an new node.
What should I do??
@Rene79 Does the dashboard show that the node is disqualified from any satellite?
Earnings are still increasing.
Only the online score is affected, so make sure the node stays online without interruption and your score should recover with time.
You need to compare the NodeID from the email with the NodeID on the dashboard. Also you should see a yellow banner on the dashboard if the node is disqualified/suspended.
And please read carefully - is it suspended or disqualified? The former is recoverable unlike the latter, just need to passing audits and being online.
From the screenshot of the reputation there is no sign of disqualification (the audit score is 100% still).
Maybe add one storage node restart to make sure the score is updated. It only gets the score every few hours so you can get disqualified or suspended without the dashboard showing it. A restart of the node should force it to get the score from the satellite. Just give it 5 minutes after the restart and look what you see on the dashboard.
